Home > 130 > Defender 130 rear seats |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17333 |
Yes, but only with some modifications.
130 and 110 DC have slightly different rear seats to SW second row:- - the brackets securing them to the floor are different. The DC brackets will fit the SW seats though, so a swap is possible. - the DC as supplied has (totally pointless) brackets securing the top of the backrests to the rear bulkhead. The only good thing about these is that they stop the seats from rattling, but they also stops the eats from tipping to allow access to the useful storage area behind and below them. There is no detrimental effect to removing these brackets and many positive benefits to doing so, but you will find that the covers of the backrest have been cut to allow the brackets to be fitted. If fitting ex-SW seats I certainly would not fit the brackets. Unless removed, these brackets also prevent the fitment of most seat covers, by the way. - the angle the backrest makes to the seat base is different on the DC to the SW seats, and I believe that this is achieved by fitting a bush (to the DC-type seat) around the locating pin in the backrest release mechanism. Somewhere on this forum there is a thread describing the removal of this bush, but I cannot immediately find it. This does however mean that the SW seats will not fit the DC unless the modification is applied to them first since the backrest will be prevented by the back of the cab from going back far enough to lock in place. As far as I know, it is quite possible to take the bushes off the seats you're taking out and fit them to the seats you're putting in. So the seats will fit and are essentially the same, but it is not a totally straightforward swap. |
5th May 2016 8:13pm |
Touchwood Member Since: 03 Mar 2016 Location: Uk Posts: 10 |
Thanks for your very reply very useful
6th May 2016 5:47am |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 334 |
This thread covers an interesting conversion: http://www.defender2.net/forum/topic22936.html Defender 130 HCPU Td5 MY2000
9th May 2016 8:37am |
Projectblue Member Since: 22 Nov 2011 Location: Devon Posts: 1096 |
Previous owner to me have done it. I have folding/tilting seats in the back of my 130DC New project and it's green: www.projectoverland.info
29th May 2016 8:45pm |
Dennis_NL Member Since: 10 Jun 2019 Location: Amsterdam Posts: 16 |
@Projectblue - would you be able to share some images of the conversion?
Currently planning mine so all info is welcome. Cheers, Dennis |
17th Jun 2019 11:39am |
Dennis, the thread I linked above is about a conversion done by a Dutch company called Landreiziger. They're located in Dordrecht. You will find detailed photos on their website: https://landreiziger.nl/2014/10/landreiziger-atelier-liu/ Defender 130 HCPU Td5 MY2000
17th Jun 2019 7:28pm |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Why do I need 5 seats nowadays? Would love to have the same done again in this one.
17th Jun 2019 8:18pm |
Thanks, I've seen that. Not sure if 3 individual seats fit in the Landreiziger configuration? Was curious about the folding 3 seat conversion that Projectblue is reffering to. |
18th Jun 2019 4:06am |
Couldn’t fit three seats in the back but wouldn’t work anyways because you need a seatbelt for the middle seat.
24th Jun 2019 12:19am |
Sorry, I meant 2/3 - 1/3 seat configuration.
24th Jun 2019 8:28am |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 |
just buy the seatbox with the seats and you will be fine. It lined up with all my original bolt holes.
There is 2" less rear leg space. i did this in mine, but went with the older 60/40 bench. But they are more comfy than the older bench seat. As the newer tdci seats lock in place, as well as offer built in seatbelt buckles. I did the four capt seats in another defender 130, and the owner loves it. Made a new seatbox for the two puma seats, and positioned them in a way to keep the rear passengers as happy as the front ones. Can't leave well enough alone |
15th Dec 2019 11:55am |
