Home > Puma (Tdci) > Inlet manifold seals |
If you want to take off the inlet manifold from the engine head you need the new seals (head-manifold side).
Land Rover doesn't sell it (Puma engine need 8 of this seals) but only the comlete kit manifold + seals and it costs a lot.... So the solution is: Go to a Ford dealer and order no. 8 seals of P/N 138 392 for MK7 Transit Puma Engine Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
28th Nov 2010 6:35pm |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
Thanks for that - I did use mine again as they were in good nick. Guys on transit forum have used them 2 or 3 times no problem. Mine seems ok also re-used
29th Nov 2010 12:21pm |
