Home > Off Topic > Structural steel work for a shed |
Phone round a few of the steel building erecting gangs, local farmers are the best to ask if none come up on Google in your area. I know of a gang by here that will do buildings of their own if they're not subbing out to one of the bigger compnies.
13th Apr 2016 11:54am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
Rather than a shed building company, what about a local steel fab place? 1999 Defender TD5 110
13th Apr 2016 12:01pm |
MagnersMick Member Since: 16 Feb 2015 Location: Overlanding America's Posts: 93 |
Yep. As above, a steel fabricator is what you need. You need a small company and these don't usually have web sites so the Internet probably is not going to help. If you know any small builders, they may point you in the right direction.
Good luck. One Life...Living it. www.rove-overland.com |
13th Apr 2016 12:25pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7906 |
I'll PM you with a relatively local fabricator. You might also want to consider a high tensile steel frame, for a small structures like this, which will probably be more economical. I'll give you some contacts.
I construct steel framed agricultural buildings for a living, but most our usual contacts would be very expensive on a small building like this. |
13th Apr 2016 1:46pm |
