Home > Maintenance & Modifications > Roll cage fitted |
AlpsLandy Member Since: 11 Jan 2012 Location: Alps Posts: 116 |
Thanks mate. 2011 Defender 90 SW
2006 Discovery 3 HSE |
14th Apr 2016 6:13am |
grizz Member Since: 31 Aug 2014 Location: cheshire Posts: 208 |
It's easy to replace a wing , it wouldn't take much longer with a sd cage than a normal wing .
The front wing outer has to be removed and modified to have the cage fitted . |
14th Apr 2016 4:46pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10742 |
Thanks Camelman, imho i think the tyres you got on now are perfect Do they come out past the arches at all ? i think if you go bigger it will look like a tonka truck, unless thats the look your after 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
14th Apr 2016 8:03pm |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2398 |
First dibs on the KO2 if you go 37"
was thinking of putting 37" maxxis trepadors on my DPCU see what comes up! 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
14th Apr 2016 8:58pm |
Click image to enlarge 37" treps fitted with +50 MM. wider arches |
15th Apr 2016 8:15pm |
Any mods suspension wise?
Im planning to put +2 OME springs with +5.5" nitro charger shocks onto my 110 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
15th Apr 2016 8:46pm |
Just +2" ome springs and +5" shocks with caster adjusted arms , it needs a little more lift so I'm fitting Spring spacers
15th Apr 2016 9:01pm |
