Home > Puma (Tdci) > Judder in 5th and 6th
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Hey all, Ive been experiencing a weird Judder only in 5th and 6th gear and only when accelerating up hill Confused
Ive checked all UJ's and flanges, they all appear to be very sturdy and well greased, I re-greased them while i was there any way.
Wheel bearing are fine as i have checked them too.
The judder/vibration is felt through the whole cab rather than just the steering wheel.
Im about to go and take the hand brake cover off and inspect in there for any binding.
Any pointers to what it could be?
Thanks
Post #522482 9th Apr 2016 1:43pm
Caterham
This probably isn't the news you're looking for.....
Do you get something similar sometimes when pulling away?
I have noticed something similar recently - a quiet slow wobble and I suspect is could be gearbox / extension shaft but most likely friction plate related?
Feels to me like the extension shaft is isolating?
Good luck.
Post #522489 9th Apr 2016 2:21pm
Roy5695
Nope pulling away is fine. Unless I'm not noticing it. It's very noticeable when it happens as it feels and sounds like something is massively vibrating in the drive line.
I originally thought it would be a UJ but I've shock them very vigorously and I could see any movement.
Accelerating down hill is fine. Just up hill when there is more strain applied.
Post #522494 9th Apr 2016 2:43pm
bell-auto-services
Is it low rpm 5th and 6th ? If so when the revs climb does the vibration stop or get less ?
Post #522496 9th Apr 2016 3:04pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
I my experience, sometimes UJ wear cant be detected unless you unbolt the propshaft.
Post #522497 9th Apr 2016 3:13pm
Caterham
Good luck Roy.
Not the same issue as me. Mine is a silent and only slight wobble under load.
Post #522499 9th Apr 2016 3:32pm
Roy5695
Relatively low and when the revs climb I feel the vibrations climb too. I've just had a look underneath after giving it a run up and down the motorway do a couple miles. The only thing I can see underneath is when I shake the rear prop the whole gearbox moves up and down. Should the mounting bushes be this soft?
Thanks for Your help so far
Post #522507 9th Apr 2016 4:06pm
PIPLANI
Switzerland 2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
I have a fairly new 2015 and the same problem.A strong judder through the cabin and driveline in 5th and 6th gear.Can you please elaborate on what you found the problem to be.
Post #526850 26th Apr 2016 8:50am
Roy5695
no solution yet, and also as the truck is in the wife's hand for the next 2 months while I'm away, no doubt there will be more problems upon my return Rolling with laughter
Post #526991 26th Apr 2016 3:26pm
PIPLANI
Visiting my dealer in the next couple of days.Will post if we find a solution.
Post #527003 26th Apr 2016 3:52pm
Roy5695
resurrecting my old thread, I have been living with this judder for a while now!!
Finally had enough of adjusting my driving style around the rev range!
New clutch, release bearing and adaptor shaft fitted at the weekend and the vibration is GONE!!!! Bow down
Just incase anyone has the same problem in the future and finds this thread, always nice to have a solution to the problem listed! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #741225 19th Nov 2018 12:20pm
Noiseydave
United Kingdom 2009 Defender 110 Puma 2.4 XS DCPU Santorini Black
My 2009 DCPU does the same, under acceleration or high throttle going up hill in 5th and 6th (although 5th seems to have less vibrations) it also groans a little. Interestingly the same hill on the way home i experience the issues on regularly with a minidigger, 3 buckets, and triple axle trailer on tow in 4th has no such vibration
We rebuilt transfer case with ATB and the input shaft changed to an ashcroft kit and it made no difference although that was not why we did the work. When we removed the box, springs and friction plate looked fine although i have my doubts on the quality of the clutch fitted (original LR with 30k on it) as has been documented many times on the forum.
All joints, shafts, mounts are ok, I put it down to the amount of torque being produced (car is remapped, bigger intercooler etc.). Adjusted driving style to reduce the occurrence but it would still be good to know what it could be and get it fixed.
Post #741230 19th Nov 2018 12:43pm
Roy5695
Did you take the clutch pressure plate off?
The actual clutch face on mine looked fine, but once removed it was like a tambourine!! the damping springs were shagged and almost to the point of falling out the friction plate. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #741240 19th Nov 2018 1:34pm
Caterham
Mr. Green what did I say ?
glad you sorted it Thumbs Up
been there, done that and got the T-shirt Laughing
Post #741241 19th Nov 2018 1:38pm
Roy5695
Haha it’s lasted over 2 years with the vibration but not sure how much longer it would have lasted.
They were ready for changing. Only done 42 thousand miles Shocked 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #741246 19th Nov 2018 2:49pm
