Home > Technical > TD5 wiper park switch (again - sorry) |
Hi James, go to this link and download what you need:
http://www.landroverweb.com/landrover/pdf-land-rover-manuals/ |
24th Nov 2010 7:38pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2653 |
Hi James
I replaced mine just a couple of months ago. Its an easy job once you get going Good luck Mark |
24th Nov 2010 8:08pm |
Mark_110DCPU Member Since: 26 Jul 2010 Location: West Sussex Posts: 78 |
On a pre-2002 td5 it's a fairly quick easy job to change the park switch - I would imagine the post 2002 would be the same:
You need to remove the bottom of the dash on the lefthand side - undo the 4 screws holding it on. The park switch is then pretty obvious on the side of the motor.. [:O|===|O:] 2001 110 TD5 Doublecab |
24th Nov 2010 10:57pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
On the post 2002 dash the motor is housed a little higher up in the dash than the earlier models so a little harder to get at. Pete. |
25th Nov 2010 12:14am |
jamesc Member Since: 19 Nov 2010 Location: Elsewhere Posts: 74 |
Thanks for the replies - very much appreciated. And sorry for taking a while to respond, I've been off air since I posted!
Looks like a finger numbing job outside at the weekend then. Cheers James |
25th Nov 2010 7:31pm |
