Home > Maintenance & Modifications > Fitting Nakatenga glove box
alantd
Below are the step by step instructions for fitting the Nakatenga glove box
The whole job took me around 30 mins - including some head scratching, various trips to my garage to fetch tools and answering the continuous stream of questions from my 3 year old son, who, on discovering my open tool box, wanted to know what everything was - and whether it was used to build trains on the Island of Sodor (reference for all you Thomas the Tank Engine Dads).
First, remove the dash panel. It uses a torx bit. Once the screws are out, you'll need to give a smart tap upwards at the front because it's also held in place by spring clips at the leading edge.
Next, unscrew the (excessively long) torx screws holding the grab handle in place and remove.
There are 3 pegs on the underside of the dash panel that need to be cut off. This is the part after which there's no going back Smile. They're pretty soft so a sharp knife will do it.
The aforementioned spring clips on the leading edge of the dash panel can then be removed with pliers. I took them off to start with but ended up putting them back on. When the whole box is assembled, the front of the 'lid' (the old dash panel) locates with some pegs into holes in the dash.
There's nothing to stop it flapping about and vibrating - hence I put the spring clips back on so that it snaps shut and stays firm. Your call. All it means is that you should remove the clips carefully in case you want to put them back.
The next job is to screw in the front panel of the box. This is dead easy using the provided black self tapping screws. Be careful not to tighten them too much as the dash is quite soft and you'll just strip it if you're not careful. In the following image, I've laid the top hinge in place just for aligning things but you don't need it - just fit the front panel snugly.
Next, screw in the hinge panel. This uses a smaller torx drive for the supplied screws. It's a bit of a pain to get to them from above (with the rake of the window meaning you can't quite get on top of them with a long screwdriver) so I used a torx bit in a 1/4" ratchet.
Again, they're self-tappers so you might want to mark the holes with a centre-punch to help but don't over tighten them. This is where it is definitely a good idea to lay the top dash panel in place to line up the hinge properly. Mostly, you're looking to get the horizontal position (left to right) correct so that the dash panel pegs line up with the holes.
On mine, I couldn't quite line everything up perfectly so I just widened the holes in the dash panel to fit the hinge screws - giving me the necessary adjustments.
Finally, bolt the dash panel back in place using the supplied washer and nuts. This is where I widened the holes slightly to allow me to fine tune the placement. There's quite a lot of give and if you have to Censored about with it too much you'll want to get some slightly bigger washers.
Et Voila! A new glove box Very Happy
Don't forget to put the grab handle back
It's a very discreet mod and looks like it was supposed to be there from the start (which begs the question: why wasn't it?).
It doesn't seem to rattle about, although I'll probably line it with rubber or felt to stop whatever is inside bouncing around.
It is VERY expensive for what it is (you could easily fashion something yourself, no doubt) but I'm quite pleased with it. Even my wife, who normally raises a wry smile at my latest modifications thinks it is fantastic (I think she has designs on it filling up with makeup brushes and general hand bag clutter) and the ultimate stamp of approval is that when I told her the price, she said it was definitely worth that! Thumbs Up
Anyway - rather long post for something that isn't too difficult (it's taken me longer to write the post than to fit the part) but hopefully it'll be helpful to someone considering one of these.
A One that started out as a 2.4 TDCi 110 XS
Post #46012 23rd Nov 2010 9:37am
The Boy
Great write up that Alan. I find myself really wanting one now.
Thank you
Boy
Post #46015 23rd Nov 2010 9:56am
BigRuss
Cheers Alan,
It'll come in Han when I get mine from glyn. Thumbs Up Russell
2011MY 110 XS USW Black
Post #46017 23rd Nov 2010 10:03am
BigMike
A great write up. Cheers Alan
Post #46022 23rd Nov 2010 10:53am
TRR Motorsport
United Kingdom 2010 Defender 90 Puma 2.4 ST Galway Green
Thanks for the great pics Alan. I looks a doddle to fab one of those up. It'll look tasty with black powder coat on the out side, and flock on the inside.
I think I'll disapear into the workshop for a while Wink "If it ain't sideways, you just ain't tryin'!
Post #46035 23rd Nov 2010 12:44pm
Lorryman100
Cheers Alan Thumbs Up
top post with a great write up and pics too Bow down Not so worried about fitting mine now, when it arrives.........
Post #46042 23rd Nov 2010 3:18pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
That's great will have to remember this post when mine comes. Thanks.
Post #46057 23rd Nov 2010 6:46pm
shingwell
Good post Alan. Have you found somewhere in the UK that sells them?
Post #46115 23rd Nov 2010 11:44pm
110SEB
TACK showed me his home made version of this mod. Certainly something I would like to do myself. Very helpful post that. Ta Thumbs Up
ps. I have a threenager as well and my tool box is a never ending source of interest for him too Thumbs Up
Post #46117 24th Nov 2010 12:06am
The Boy
Don't think it get any better when they get older. My youngest son is a nightmare even when I lock the cabinet he finds the spare keys and I am constanly looking for lost spanners. The ones he does put back are always in the wrong place!!! Still i have a break now as he is in Afghan, and I kinda miss him but my tools are tidy though. Laughing
Post #46125 24th Nov 2010 8:11am
jst
excellent post. something i should get around to doing. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #46240 24th Nov 2010 10:00pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
I fitted mine a few weeks back. Didn't reuse the clips but I'm thinking of doing so. I also placed some thin rubber strips down either side to stop the lid rattling. I'm yet to get some felt to line it with.
Very happy with it. SWMBO thinks its great. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #46344 25th Nov 2010 7:42pm
i have a home made glove box similar.
1. bought a couple of small hinges
2. used araldite to glue them into the top part (lid), this was then screwed onto the top of the dash.
3. spent some time figuring the best material to make the base/shelf, in the end i found some 8mm black plastic sheet, made a cardboard template and cut out the base.
4. screwed and glued the base / shelf into the dash
5. cut off the LR hex self tappers and glued the tops of the screws onto the lid
discreet glove box - cost about £7.00
Post #46873 1st Dec 2010 6:14am
TACK
Thanks Seb.
So easy to do, about £5 for a hinge from B&Q and a bit of black plastic from a sign writers which cost £1. Sahpe the plastic in a vice with 2 bits of wood. Mr. Green
Post #46882 1st Dec 2010 8:30am
Naks
TACK wrote:
Tack, what is that on the dash, below the passenger air vent?
Post #46895 1st Dec 2010 9:37am
