Home > Wheels & Tyres > Tyre wear - when to replace?
Page 3 of 3 <123
YOLO110
Australia
Moving this thread on a bit... i.e.: lock the centre Diff...
I would be interested in thoughts regarding having new front tyres with 12mm tread depth vs old rear tyres having 3mm tread depth... (or the other way round being P.C!)
Would there be any drive train wind-up here as a result of the (slightly) different rolling circumferences of the tyres F/R?
Whistle YOLO... You Only Live Once...
Post #519031 29th Mar 2016 7:55pm
Cetane
United Kingdom 2010 Defender 110 Puma 2.4 HT Galway Green
Yup
Post #519034 29th Mar 2016 7:59pm
miker
So assuming 265/75/16 Tyres, and some assumptions:
3mm of tread gives rolling circumference of 2531mm
12mm of tread gives rolling circumference of 2587mm
So for every rotation the newer tyre would want to go 5cm further each rotation.
so yes, it would wind up gradually.
However, as you only use it when traction is likely to be lost, the slip would sort it out.
Post #519035 29th Mar 2016 8:00pm
Rickydodah
Quote:
The odds of someone spiraling out of a corner and hitting you is far less than someone failing to come to a stop in a timely fashion. Who in their right minds drives on the limit of lateral grip on the highway???
Unfortunately national accident statistics don't support this. However I'm sure now with the authorities reluctance to investigate non injury accidents that their data is incomplete, the only indication to support the prevalence of the rear end shunt is the rise in whiplash claims.
I see what you mean now with the compound question, which supports what I've been saying, the tyres with the best grip should be on the rear. Tread depth is not always indicative of grip levels. Weight transference under braking is a different dynamic and not solely reliant on tread grip, anti lock braking can cause the tyre with the best grip to do the least of the braking. Interestingly as you've mentioned lateral forces versus braking efficiencies this tends to be more influenced by car design and weight distribution, any consequence of tyre design compromises are unfortunately a fact of life, you seldomly get to have your cake and eat it. Directional tyres, asymmetric tread patterns went some way to helping but are more to do with straight line stability but some are particularly good at water diversion on wet roads. I started with nothing and still have most of it left!
Post #519041 29th Mar 2016 8:06pm
YOLO110
Australia
Good old Pythagorus! (well his cousin then!! Laughing )
Thats actually quite a lot...
So going back... replace all 4 then... having rotated them for an even life of tread wear. Thumbs Up YOLO... You Only Live Once...
Post #519042 29th Mar 2016 8:07pm
YOLO110
Australia
[quote="Rickydodah"]
Quote:
etc etc... Directional tyres, asymmetric tread patterns went some way to helping but are more to do with straight line stability but some are particularly good at water diversion on wet roads.
Tread on a tyre on a dry sealed even road does nothing to contribute to 'grip'... either cornering, braking or accelerating. Thats is why F1 and all other racing cars run slick tyres (NO tread)... to maximise grip (contact patch friction) in the dry (and perhaps also in the damp too!)
However, tyre tread indeed has a massive contribution to play in the wet when there is water 'standing' between the road surface and the tyre contact patch, shedding water at many litres/second when moving which allows them to maintain contact with the road surface beyond what is theoretically possible above aqua-planing speed, 9√p, where p is tyre pressure. So at 40psi, this predicts a Defender will aquaplane at 56 mph... when in reality it's probably more than that, given experience on wet motorways at 70 mph.
Road cars legally must have tread... because the roads get wet from time to time!! 4WD specialist tyres have more because we like to play in mud/sand/rocks etc etc!
(The Boeing aircraft I used to fly had the tyres inflated to about 170 PSI... which gave an aquaplaning speed of about 121 mph. However, they also had a simple grooved 'circumferencal tread' which moved them up towards the normal landing speeds of circa 145 mph...)
All good stuff. Thumbs Up YOLO... You Only Live Once...
Post #519052 29th Mar 2016 8:27pm
Cupboard
Pythagoras was triangles Rolling with laughter
You won't get wind up because when you're on hard ground the centre diff will take it out, and when you're on soft ground wheel slip will take it out.
Post #519053 29th Mar 2016 8:27pm
Cetane
Absolute tosh
Do you understand how ABS works?
The system looks for a wheel locking then "releases" it. So if a wheel has more grip it will retard the vehicle more before locking and subsequently being unlocked by the ABS system.
Physics applies to all cars, and they will all have load transfer to the front under braking. That is unless the CoG is below the tyre contact patch.
Wrong. Asymmetric tread allows water to be cleared in a straight line but offers a more "dry" focus in cornering. Have another look at a good asym tread. The outside usually has fewer channels/sipes and more rubber in contact with the road. As you load up the tyre laterally the contact patch changes and you will be running on thie dry focused part. This layout allows for tyres to be a decent "all rounder"
Please don't lecture me on vehicle dynamics. It's my background.
Post #519056 29th Mar 2016 8:30pm
Screbble
Cupboard wrote:
Have you seen this video miker?
Start at about 1 minute.
Excellent video and great advice Thumbs Up
Post #519083 29th Mar 2016 9:40pm
Rickydodah
Cetane wrote:
Absolute tosh
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter I started with nothing and still have most of it left!
Post #519145 30th Mar 2016 8:21am
Page 3 of 3 <123
