Home > In Car Electronics > Not starting, post clutch change. Help!! |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5804 |
Video of the fault
Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
12th Mar 2016 3:34pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20300 |
Makes me wonder if it's the ignition.
12th Mar 2016 4:41pm |
Tumich Member Since: 09 Apr 2013 Location: Prague Posts: 9 |
try to move the small battery in the imobiliser on your keys -
it happend to me quite offten or the Neg on battery is loose, hope this helps |
6th Jul 2016 12:25pm |
Is your key fob working to switch immobiliser off you may need to re sync to key fob by holding down unlock button on the key fob till the dish immobiliser led go out
now with all doors closed arm the alarm and dis arm the alarm had same problem with mine post clutch change |
6th Jul 2016 12:40pm |
Hello Tumich and Dorsetsmith. Should have mentioned that it's sorted. Loose wire in the area of the fuse box. Monsieur Le Grenadier
6th Jul 2016 12:53pm |
good
6th Jul 2016 12:56pm |
