Home > Puma (Tdci) > Oncoming lights reflections |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
This has been discussed at length many times before.
Tinting makes no difference, there is absolutely nothing you can do about it. It is indeed due to the angle of the rear glass acting as a mirror to oncoming lights which are then seen in your rear view mirror. Just something you have to get used to, or, remove the rear view mirror as some have done. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
11th Mar 2016 9:16am |
neil5886 Member Since: 15 Feb 2016 Location: York Posts: 24 |
Okay thanks for the reply, my old 110 didn't have a rear window so this reflection issue is new to me.
I am useless using the forum search I can never find anything. |
11th Mar 2016 9:48am |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
Is there any requirement to have the rear view mirror? Mine's pretty pointless and I don't have a rear wiper either.
11th Mar 2016 9:50am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17335 |
Yes.
C&U (as far as I recall) requires that a vehicle is fitted with a minimum of 2 rear view mirrors, one of which must be external and on the offside. the other can be either internal or external and on the nearside, but must be internal unless for some reason an internal won't give a view to the rear. So stricly speaking if you have a rear window, you must have an internal rear view mirror. This is a change from a few years ago when there was no restriction on the second mirror and either internal or external was acceptable without qualification. I suggest you're unlikely to be stopped, and I don't think it is an MOT failure as long as you have two mirrors. |
11th Mar 2016 9:53am |
If you want to see what its like to not have a rear view mirror you can easily remove the original quickly, and replace in a matter of seconds.
Grab the arm firmly and turn the entire unit clockwise or anti clockwise, it will then release. You can look at the spring mechanism after to easily see how it goes back on. This is what the base plate looks like. Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
11th Mar 2016 10:01am |
It's been a quirk of the vehicles for the past few decades, you quickly adapt. I wouldn't even bother removing the mirror, just ignore it and use the exterior ones instead. Steve.
11th Mar 2016 10:38am |
It would be quite a handy place for a screen, either phone or rear view camera.
I'm getting increasingly motivated to fit a reversing camera because I've got issues with a particular car park. |
11th Mar 2016 10:45am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Mud do a fab Bracket my Sat Nav is mounted there (At times)
11th Mar 2016 11:34am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Imo,remove internal mirror,then save thousands on rear wiper blades/motor repairs etc.IF any police/vosa pulled you I doubt very much they would mention a missing interior mirror,at the most it would be a recommendation.
mot; http://www.motuk.co.uk/manual_810.htm cu regs; http://www.transportsfriend.org/road/mirrors.html Also rear wiper is not a testable item,so doesn't have to work. Pov.spec,ftw. 2006, 110,TD5. |
11th Mar 2016 3:51pm |
Christian1402 Member Since: 17 Feb 2016 Location: Cumbria Posts: 214 |
My hard top didn't have a rear view mirror, yet the bulkhead was a standard one, not full height.
I just presumed they came from the factory like this. Either way it didn't both me, the rear view mirror of my discovery is useless due to the 3.5" lift and huge spare tyre. I'll probably remove the one from the xs when I get around to it, as the reflecting light does annoy me |
11th Mar 2016 5:40pm |
I have a 110 HT with no lift and the smallest tyres you get on a Defender. The rear view mirror is still completely useless for manoeuvring.
11th Mar 2016 9:23pm |
Riccarton Member Since: 10 Aug 2015 Location: Gods' Own Country Posts: 280 |
Any idea when this changed? It used to be "a) an external mirror on the offside and b) an external mirror on the nearside OR an internal mirror." Thereafter, any additional mirrors were not testable items. I often wonder why they can't just leave things alone that don't need fixing and yet leave alone things that do need fixing !! |
12th Mar 2016 9:17am |
Almost certainly Europe has something to do with it. It is fairly recent.
12th Mar 2016 7:31pm |
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 |
I am in agreement with happy/ miserable just man up and live with it. Just another Defender quirk, I have got used to it. Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
13th Mar 2016 2:02am |
