Home > Puma (Tdci) > draining fuel filter
davidpalfreyman
2009 Defender 110 Puma 2.4 CSW Alpine White
Manual says you need special pump to prime the system after replacing fuel filter or even after draining any water from bottom of fuel filter.
Is this true? Thanks
David
Post #44975 11th Nov 2010 6:58pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Can't say for sure - but in this month's LRO mag in the new products section there is a tool which re-primes the fuel lines - the 'sales' blurb basically says you can't change the filter without using one. However, I wonder if one of the experienced readers has a trick? I think the tool was £90 from memory - but if you have to replace your filter or drain off water in the field then £90 well spent. I'd be keen to understand if anyone has a simple trick to do this.
Post #44983 11th Nov 2010 7:44pm
fekete
some have just fill the filter and replace Thumbs Up
Read this http://www.defender2.net/forum/topic516.ht...uel+filter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #44989 11th Nov 2010 8:34pm
RED-DOT
Yes, just fill with fuel and refit but i half fill it with "Forte" Diesel treatment... i once used a dry filter and it started after 3-4 attempts. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #45120 13th Nov 2010 9:05am
