![]() | Home > Maintenance & Modifications > engine block welded crack leaking ( 2,2 puma) |
pressbrake Member Since: 06 Oct 2012 Location: essex Posts: 31 ![]() ![]() ![]() |
I have successfully welded engine blocks with pure nickle rods
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
there is a 2.2 puma engine on eBay uk today could be worth a look
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 252 ![]() ![]() ![]() |
mig welding cast iron - http://www.mig-welding.co.uk/cast-iron.htm 1953 80"
1987 mini city e 2011 90" |
potspeedy Member Since: 13 Feb 2016 Location: Bucharest Posts: 14 ![]() ![]() ![]() |
Got the new one! Thanks guys for the advice.
![]() Click image to enlarge 2012 MY, Defender 110, 2.2 Puma 2016 MY Range Rover 3.0TDV6 Autobiography past: 2015 MY Range Rover 3.0TDV6 Vogue 2013 MY Range Rover 3.0TDV6 Vogue |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2457 ![]() ![]() |
Good luck with your rebuild!
have you ordered your chassis yet? 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
Thank you, there's a lot of work to be done. I did not expect it to turn this way.
The chassis is ordered and paid, I will get it delivered on the 1'st of April. Now the car looks like this: ![]() Click image to enlarge 2012 MY, Defender 110, 2.2 Puma 2016 MY Range Rover 3.0TDV6 Autobiography past: 2015 MY Range Rover 3.0TDV6 Vogue 2013 MY Range Rover 3.0TDV6 Vogue |
