Home > Puma (Tdci) > Engine starting
Mcd
United Kingdom 2012 Defender 90 Puma 2.2 HT Cairns Blue
Engine starting
Hi
Defender 2.2
Twice the car engine has crancked but not started and yesterday I turned the ignition key but did not turn over
Any ideas would be a great help
Post #505422 17th Feb 2016 9:21am
Have you simply flattened your battery?
Turn your lights on, are they full strength of barely glowing?
Does the key fob work normally with the correct number of flashes on lock and unlock? When did you last change the key fob battery?
Post #505447 17th Feb 2016 10:02am
