Home > Maintenance & Modifications > V8 transplant |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Cost of engine £450-£8000
plus Cost of transmission ??? Using existing manual or going auto? Fuel pump replaced. Replacing dials Wiring Looms Engine mounts changed on chassis Replace Exhaust Lambda Sensors then the labour.... Sorry to be vague but you give little info. |
12th Feb 2016 6:35pm |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2640 |
v8 ls3 is probably 18 - 20k done properly
v8 supercharged from a rr? lots of wiring. |
12th Feb 2016 6:56pm |
Vipergts Member Since: 02 Oct 2012 Location: Kent Posts: 39 |
Manual
But obviously quite a lot needs doing and probably out of the budget |
12th Feb 2016 7:41pm |
