Home > Maintenance & Modifications > How to Install Steering Protection Bar??
hw7905
Hong Kong
Is that I only use the four existing nuts to fix it to the front underbody?
And which four nuts are they? Anything else to note?
And what is the use of the long bolt in the picture?
Thanks for telling Smile
Post #503751 12th Feb 2016 4:20am
dorsetsmith
you have all the parts you need
next you will need time and tool to undo 4 nuts and remove one bolt to be replaced extra long one and spacer
Post #503828 12th Feb 2016 9:58am
hw7905
Hong Kong
Thanks.
Sadly I just found out the nut on the extra long bolt is broken and cannot be screwed onto the bolt any more Shocked
The nut has a unique shape, like with a built-in ring at its bottom. Anyone knows its part number please? I bet it is 3/4" nut.
Or just a nut from a local hardware shop with a ring added to it will do? Pls advise as I duno much about mechanics. Thanks.
Post #503971 12th Feb 2016 4:30pm
dorsetsmith
it is ni-locknut
Post #503980 12th Feb 2016 4:48pm
Happyoldgit
With the greatest of respect may I suggest you take your vehicle and the bar to someone competent who can assist with fitting this for you. Steve.
http://forums.lr4x4.com
Post #503992 12th Feb 2016 5:16pm
Romadog
Ditto Thumbs Up
Post #504018 12th Feb 2016 6:14pm
hw7905
Hong Kong
Thx for the advice. Eventually, I asked my friend to install it for me:
Post #504282 13th Feb 2016 1:37pm
