Home > Puma (Tdci) > Turning on lights when cold |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6315 |
not sure here BUT
I recall with my last one going into the work underground car park and getting a similar noise.... (now this is where my memory lets me down) seem to recall it had something to do with the loss of radion reception (sounds strange I know) - dont know about the dim lights though. |
4th Nov 2010 11:21pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
It'll be the headlamp relay that needs replacing or it's making a bad contact in it's socket(common fault).
It's 'buzzing' instead of closing completely. Try it on beam instead of dip and see if it still happens. (should be a different relay.) Its only happening after a cold start because the battery voltage will have dropped slightly after the starter load. |
5th Nov 2010 12:27am |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Cheers chaps!!!
5th Nov 2010 11:56pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
yep, Lauries dead on 2.4 90 XS
6th Nov 2010 9:51am |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Yep Laurie is right,
I had a similar problem some time ago: headlights flickering at the begining and take a time to start. Finally the ligths stop to work and the relay were replaced (pretty easy work). Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
6th Nov 2010 9:58am |
