Home > Technical > Rear brake problem - any ideas
red squirrel
2007 Defender 90 Puma 2.4 SW Cairns Blue
Rear brake discs both appear to have surface corrosion even after several emergency brakes. They do not return to the shiny state I would expect after normal braking. There is no difference between left and right rear discs but a big contrast with the front discs. I suspect either Pressure Control Valve or Master Cylinder? Any thought please? (Rear disc and, for comparison. front disc pics attached)
Post #503078 10th Feb 2016 1:13pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Think I would go for a set of discs and recon or new calipers Thumbs Up
Post #503086 10th Feb 2016 1:30pm
red squirrel
Thanks for the idea...it had new calipers and discs fitted in July last year so am assuming they are not the cause.
Post #503089 10th Feb 2016 1:37pm
Happyoldgit
I'd get it on a brake tester. Steve.
http://forums.lr4x4.com
Post #503161 10th Feb 2016 4:19pm
miker
Or jack a rear wheel up, have an assistant apply the brakes and see if you can turn the wheel. Often you have to apply the brakes really hard to get any decent braking force out the rears. Especially when unladen, the bias valve will reduce the braking force to the rears.
Post #503164 10th Feb 2016 4:25pm
Without diagnosing the root cause? Seems an expensive and haphazard way to go.
Have a look at the rear pads on both sides of the caliper, are they equally worn? Also, are the inside faces of the rear discs as equally rust stained as the outer faces?
Do you have any old pads? If you can get a set, swap them out and have someone operate the foot pedal whilst you watch the caliper to see if the pistons have a full free range of movement. You can use a block of wood if you have no old pads - it's just something to limit the piston movement range and stop them coming out too far or falling out completely. Try to see if you can push them back in fully by hand, it should not be too easy but equally it should feel smooth and consistent.
Your issue could also be with the fluid getting to the caliper. Is the condition of the flexible hoses good, no leaks, bleed nipple clean and air tight?
Post #503395 11th Feb 2016 9:51am
The pistons could be sticking in the rear calipers. Try pushing the pistons back in the bores and assess how easily they move.
Post #503399 11th Feb 2016 10:06am
