Home > In Car Electronics > Dash illumination
Stiff1
Dash illumination
Hi have been messing with the double din dash a bit lately, finding best location for switches and have noticed my head light alignment dial and lighter are not illuminated, otherwise both function correctly.
Can anyone confirm that they do in fact illuminate? (2007 CSW).
Thanks in advance.
Post #502969 10th Feb 2016 12:08am
The socket should be illuminated certainly, and I imagine the headlight adjuster switch too, though I can't say for sure since my vehicle doesn't have one.
Post #503020 10th Feb 2016 9:39am
ericvv
On a standard dash the headlight adjuster switch itself is not illuminated, but the vertical 0 to 3 numbered little strip is illuminated. As is the 12V power socket.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #503023 10th Feb 2016 10:02am
Stiff1
Ok thanks, will see what I have done now!
Post #503112 10th Feb 2016 2:46pm
