Home > Puma (Tdci) > Is it normal... |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 |
..OK, so (as you read in another thread) I've just got my new (4 month old) 110 USW.
Quick stupid question. On starting up, there is a brief 'clunk' type sound from near the steering column. Goes immediately, but does it every time on startup. Is this normal? Cheers, James P.S. Just did my first mods to the truck (what do you mean it took me three days of ownership?). Mud Rails - Best invention ever... Plus Kenwood KIV-700 head unit. Much much better sound. Now to replace those horrible front speakers... 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
4th Nov 2010 11:19am |
Thanks Nick.
Thought it must be normal. but you never know with a Defender... Yes, the mud rails are great. Ironically, I didn't move my seat a lot further back, despite being 6'2, but the raised driving position just seems to make everything a little more 'ergonomic'... Am replacing the grab handles with these: http://tinyurl.com/366t83u which should get rid of the handles digging in my thigh problem. Good idea with the USB splitter on the KIv-700. At the moment I have the lead trailing to my cubby box. I bought the add-on BT box, too. where did you mount yours? James 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
4th Nov 2010 12:22pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
i like the look of the handles, you do seem to get an indentation in your leg
the bt box i've located behind the flap in the dash board in the n/s footwell i have found on a couple of times, that the plug for the bt box comes loose frome the back of the head unit (only slightly) but enough to sopt it working. we've got quite a bumpy track to our house. i've got to try and fix it more permantly. I'm also on the look out for a dab box for it. |
4th Nov 2010 12:52pm |
Hi Nick,
Just to let you know (in case you didn't) that there is a recent firmware and software update for the KIV-700 on the Kenwood website. http://www.kenwood.com/cs/ce/receiver/firmware/2010/ord_eng.html Just download onto a USB stick and follow the instructions. Supoosedly adds a few improvements. Can also recommend the Pure highway as a low-cost DAB solution. Used to work really well in my Golf. My aim is to use the aux in on the KIV-700 to connect directly to the aux-out on the Highway (thus avoiding the FM transmitter), with the stick-on glass aerial mounted on the alpine window (I have privacy glass so you can;t really see in to the alpine window anyway). The Pure unit iself can either sit in the cubby box or on dash shelf (IN only tend to use it for Planet Rock and Radio 4 anyway). James 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
5th Nov 2010 2:09pm |
Thanks for the nod on the firmware update.
I didn't realise you could connect the pure high way in this way - i'll take another look at this then. So the highway unit could actually be fitted into the cubby box as tis got an external antenna, as its not the best looking unit. |
5th Nov 2010 3:08pm |
