Home > Maintenance & Modifications > After-market seat options. |
@ RCMike, you can raise the rear fixing point by a couple of inches, my tapered seat rails go from nowt to 2 " at the back. All that I did was to drill through the box parallel to the seat box. You need to extend the fixing points on the seat bases by 2" or so to match the LR seat fixing points anyway so I welded flat steel to extend them and then welded some flat at 90' to catch the holes I'd allready drilled in the box I had bolted to the seat base. That provided me with a simple but strong hinge.
10th Feb 2016 9:55pm |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 |
I fitted these. There is enough gap under the seat to get a set of jump leads in for example but anything more involved its 4 bolts to undo them and lift up.
I also have RAC cover so if something bad happened I'd just get it recovered so I could deal with it in daylight or back at home. Click image to enlarge 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
10th Feb 2016 11:19pm |
