Home > Puma (Tdci) > front diff oil seal |
see below...
M12 x 30mm if Parts manual is correct! Last edited by Supacat on 4th Feb 2016 3:26pm. Edited 4 times in total |
4th Feb 2016 2:54pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17382 |
From the Puma WSM:-
Installation 1 . Clean pinion oil seal recess and pinion flange. 2 . Lubricate oil seal lip with clean oil. 3 . Using LRT-51-010 fit pinion oil seal. 4 . Fit pinion flange. 5 . Restrain flange using LRT-51-003 and fit bolt. Tighten bolt to 100 Nm (74 lbf.ft). 6 . Position drive shaft to differential housing and align reference marks. 7 . Fit flange bolts and tighten to 48 Nm (35 lbf.ft). 8 . Remove stands and lower vehicle. 9 . Top-up differential oil level. This is curious since the "Torque Specifications" table at the beginning fo the WSM section says:- Bevel pinion nut 130 Nm ... even though (a) this conlficts with the section quoted above, and (b) the bevel pinion on all Pumas is retained by a bolt not a nut. The Puma WSM is riddled with errors, contradictions, and anomalies like this though. I've always gone with the 100Nm figure. |
4th Feb 2016 3:18pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
Isn't there a flange tool required for this or at least fashion something of your own?
Maybe the OP has this but I swear it is needed to tighten it up. Tis' worth checking the flange isn't worn too wwhile at it or it may still leak even with a new seal. |
4th Feb 2016 5:18pm |
Yes, LRT-51-003, but it's very easy to make one or to improvise.
4th Feb 2016 6:27pm |
4th Feb 2016 6:34pm |
giacomo.m Member Since: 06 May 2011 Location: Roma Posts: 15 |
Thank you blackwolf
Giacomo |
4th Feb 2016 8:39pm |
John110 Member Since: 20 Nov 2011 Location: Co. Meath Posts: 106 |
I just failed our equivelant of your mot today with this leak. Thanks for the guidance- I'll be tackling it over the weekend
Cheers John For those who understand, no explanation is needed... For those who do not understand, no explanation is possible |
4th Feb 2016 10:45pm |
Failed for a leak ? Was it particularly bad.
I had an advisory for the rear when I had it but it was a weeping leak and UK MOT. Is yours different / more stringent then? |
4th Feb 2016 11:39pm |
Not too bad, axle was wet but not leaving a mark on the ground after parking. I thought he was a bit harsh. I'd imagine it's tougher over there with vosa stopping hgvs and checking them day and night
5th Feb 2016 7:53pm |
MikeJ Member Since: 04 May 2014 Location: Dorchester, Dorset Posts: 41 |
Thanks for this write up - changed the front seal on my 130 cherry picker today.
I simply put it back on the wheels to tighten up the pinion bolt - no special tool required! Sadly, the leak has turned out to be a cracked weld on the axle. Mike |
30th Jul 2017 4:07pm |
Mike, is the crack in the weld holding the end flange to the axle tube and is it 2012 vehicle? If so, read this thread. There was a recall for this on 110 and 130 models, but not 90s.
30th Jul 2017 8:42pm |
Thanks for the heads up on this.
It's a 2012 2.2, and I think the recall doesn't include my vin number. The crack is in the seam along the front of the axle close to the nearside end. It's a 3.5 tonne cherry picker and has HD suspension, so I'll speak to a dealer. In the meantime, I stuck some chemical metal over the crack to try and keep the oil in. Cheers Mike |
31st Jul 2017 6:33am |
