![]() | Home > Maintenance & Modifications > 30ltr additional fuel tank for Defender 90 |
James we have the TDCi from VIN 8A on our shelves. I will check availability on the earlier ones tomorrow as I am at the factory collecting wheel carriers etc.
Fitting a wing tank with a roll cage fitted will probably mean modifying the roll cage mounting points by a competent person. I The balance pipe goes from the side of the wing tank close to the bottom into the side of the main tank. Will also check max tyre size with the wing tank. Brendan |
TD5 and early tanks are off the shelf
Max wheel size is 285 HTH Brendan |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8191 ![]() ![]() ![]() |
thank you Brendan, is that £240 including VAT? Cheers
Our prices are retail so include VAT
What is not included is carriage costs. Brendan |
thank you Cheers
