Home > Puma (Tdci) > Horn not working
Defender Singh
Horn not working
Hi the horns have stopped working on my puma,I've checked fuses and switch with tester and receiving voltage at horn connection,the alarm had also stopped beeping,I've replaced the stalk recently with loom upgrade so switch is new and to make sure I've tested it with a bulb connected.
I know electrical items can fail but both at the same time!
Any advise welcome
I've ordered a pair of stebel horns to replace the old ones.
On top of that passenger wiper died,dash out wiper box or rack or both?
Post #497501 28th Jan 2016 6:10pm
stanley
Check the wire hasn't chaffed behind the off side headlight , that's what happened to mine
Fixed under warranty so no photos unfortunately
Post #497504 28th Jan 2016 6:14pm
Defender Singh
Horns
I checked the o/s not the n/s I'll have a look at that thanks
Does anyone know where to get the original type horn connectors so I can keep the loom intact?
Post #497507 28th Jan 2016 6:23pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Since a couple of months my horn was also working only intermittently.
It turned out that one of the horns developed an internal short circuit.
Upon removal of the faulty horn the other one suddenly sounds more powerful !
Now I need to source a new horn, as a single horn doesn't sound very nice Laughing Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #805246 7th Dec 2019 7:58pm
