Home > Maintenance & Modifications > Wiring warn winch
fredbloke
Wales 2010 Defender 110 Puma 2.4 XS DCPU Firenze Red
Wiring warn winch
Hi, im trying to wire a warn eb12000 winch to my puma defender.
Not done this before so where is best to send the two thick wires?
Also trying to wire in one of those wireless winch remotes. If anyone has a diagram of the inside of the warn winch i would apreciate it.
Post #496968 27th Jan 2016 11:52am
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
You will need to wire the winch back to the battery box under the seat, best way is to run the cables underneath on top of the chassis rail to keep them from being damaged. Don't forget you will need to fit an isolator switch inside the cab somewhere, I fitted my isolator switch on the front of the seat box.
Post #496973 27th Jan 2016 12:05pm
