Home > Maintenance & Modifications > Battery Leads for Dual Battery Installation ?
Page 3 of 3 <123
Cupboard
Have you got any more information about that dual battery tray? It's hard to find something that isn't designed around the Odyssey batteries.
Post #551809 28th Jul 2016 8:24am
mikeh501
going back to where to source the cables..... i had all my larger battery/winch cables made up by vehiclewiringproducts. They will cut them, crimp them, solder and heat shrink each cable you need with the ends you specify. They do a great job and its not much cost beyond the actual the cost of the cable they supply. Definately not worth buying the expensive crimping tools you need for 35mm+ cable.
Post #551829 28th Jul 2016 9:50am
Cold_n_Wet
Norway
@Cupboard
http://gmb-mount.de/shop.htm?http://gmb-mo...htm~inhalt
[img]http://gmb-mount.de/ware_D801.htm#[/img]
Glen LB6WG "Rafiki" 2007 110 STW - Rolling rebuild.
Post #551900 28th Jul 2016 2:52pm
Page 3 of 3 <123
