Home > Technical > Offside twang then rubbing/grinding noise...
MrOl
So driving along and then loud 'twang' noise (a bit like elastic snapping) and then sort of rubbing/grinding noise as you slow down. Done it twice now, possibly 3 times (wife was driving that time and she isn't 100% sure) over last month or so. 1st time rubbing noise continued when driving forward but then put into reverse to turn around and when pulled forward it was all back to normal. Second time had to put straight into reverse to get off road and out of way and again, all fine again when pulling off.
Any ideas on what it might be and how serious?
Post #493410 17th Jan 2016 8:05pm
ickle
stone in disc / caliper?
Post #493441 17th Jan 2016 8:47pm
Pilgrimmick
CV joint? 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #493501 17th Jan 2016 10:08pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
It might be worth checking that one of the rear springs hasn't become slightly detached from the top collar.
I had this happen on my 110 and found that the intermittent rubbing noise was the spring touching the tyre. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #493519 17th Jan 2016 10:51pm
Mo Murphy
It does sound like a dislocated spring.
50 Shades of Pennine Grey
Post #493524 17th Jan 2016 11:04pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Check steering damper hasn't loosened off.
Post #493559 18th Jan 2016 7:01am
MrOl
Thanks all - will try and have a look for each of these tonight.
Post #493561 18th Jan 2016 7:24am
