Home > In Car Electronics > Twin USB unit in 2007 Defender.
Toplink
Just wired in a twin USB unit, piggy backed on to lighter socket for feeds as won't be using at same time. Works as it should BUT I now get lots of interference on BBC radio 2 radio 4 and local is ok! Any suggestions please. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2014 Triumph Tiger800xc
1999 Discovery 2 td5
1982 Ransomes TSR300D.
2002 Yamaha XT600e.
2010 Freelander2 (the wifes)
2008 John Deere X140
Post #490689 10th Jan 2016 6:12pm
miker
Honestly?
Cheap crappy chinese switch mode PSU with poor EMI performance, causing the noise.
Post #490699 10th Jan 2016 6:39pm
If you are not going to use it at the same time as the 12v socket, why not just plug a quality dual USB in?
Post #490701 10th Jan 2016 6:42pm
Toplink
In fairness not a cheap unit. and plugging in a unit to the lighter socket looks naff. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2002 Yamaha XT600e.
Post #490753 10th Jan 2016 8:36pm
miker
Got a link? To be honest, even a lot of the not cheap stuff often has poor EMI performance. Could be worth getting a replacement? Might be a build issue.
Post #490755 10th Jan 2016 8:41pm
Caterham
Just a thought - do you have the + a - crossed over?
No sure this would cause the problem but the USB device might have still work but cause problems?
Post #490763 10th Jan 2016 8:52pm
camelman
I bought a really low profile, dual plug in jobbie of ebay for Ł4 and it sits almost flush with the dash so looks (almost) OEM.
No interference either.
Post #490766 10th Jan 2016 8:55pm
^^ Thumbs Up me too
Post #490774 10th Jan 2016 9:06pm
kmac
have a look at this thread - i had exactly the same issue and fixed it with a choke mode filter
http://www.defender2.net/forum/topic32439.html?highlight=choke
Post #490778 10th Jan 2016 9:11pm
Cheshire110
this blue sea one, although not the cheapest, fits in the exact same hole as the standard 12v socket in the front dash, and has the same connections at the rear Thumbs Up
http://www.mudstuff.co.uk/products/electri...ocket.html Cheers, David
Post #490779 10th Jan 2016 9:12pm
familymad
That looks like a great bit of kit. Children were just asking how to charge the iPads in the vehicle. 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #490789 10th Jan 2016 9:37pm
Cheshire110
Not fitted mine yet (haven't got the car yet!!) but have offered it up to the facia and it fits beautifully.
And at 2 x 2.1A will handle 2 iPad/iPhones at full power. Cheers, David
Post #490791 10th Jan 2016 9:40pm
Toplink
SeaIt is a Blue Sea one. a filter is next on list to try and fix. Its never over in my land rover.
2007 Defender HTop.
1952 Series One 80"
1977 Muir-Hill 111.
2002 Yamaha XT600e.
Post #490796 10th Jan 2016 9:54pm
Cheshire110
If you're saying it a blue sea one you have then I suspect a fault, as they make great stuff.
Or maybe wire is excessively close to aerial?
Or you have slightly pulled the aerial out of the back of the radio? Cheers, David
Post #490799 10th Jan 2016 10:01pm
excossack
I too have a blue sea one fitted to the side of my mud stuff dash pod (td5). When I have a phone on charge the radio signal drops off. As soon as I unplug the phone all is well.
I have a cheap twin USB into a ciggie socket just below the blue sea one and that is fine - no interference with the phone on charge, Both off the same power feed. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #490885 11th Jan 2016 9:04am
