Home > Maintenance & Modifications > light bars, spot lights, Mounting without Drilling / wiring
Stacey007
Hello
While in the Lakes a few other Defender drives not only waved at us but also we had the full beam of the roof lights,
The Mrs liked these a lot Smile so not one to miss an opportunity while Its rare I get the actual OK to spend on my Defender...
Can you get a bar that doesn't need to be drilled into the gutter?
How are the lights wired in (I guess a hole has to be made for the cables?) where does this run to.
Any pictures people have of their set ups, round lights , square, led etc...
Many thanks
This is the type of bar I guess but would rather not have to drill?
Post #489780 7th Jan 2016 11:04pm
IIRC D44 used to do a clamp on light bar. Couldn't find it on the site the other day but maybe have a look.
Cable routing, a RAI or Snorkel is ideal to route them if you have one?
Post #489781 7th Jan 2016 11:10pm
Mean Green
You can get clamp on bars and cables can be run up behind the door seals without needing to drill anything. At most you might need to take a little 'check' out of the corner of the door pillar but it is hidden by the seal and if you are really worried about leaks a spot of silicon will seal it up.
The cable comes out of the front corner of the door just at the gutter and on to the bar. very little exposed wire.
Post #489795 7th Jan 2016 11:33pm
leeds
Nakatanenga do a stainless steel light bar which clamps onto rain gutter, powder coated one here
4 brackets for lights plus a bracket for an aerial
Brendan
Post #489796 7th Jan 2016 11:36pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
Cheaper one here. http://www.johncraddockltd.co.uk/accessori...mark.html. The Nak one is likely much better depending on your budget. North Cumbria Search and Rescue - Team Leader
Post #489801 7th Jan 2016 11:41pm
Stacey007
Hello
Both thank you ^
I actually prefer the unbranded one without a motif even if that would be better long term? At £55 On a black Defender it should almost blend in,
It would need some black caps over the bolts, I did notice the 'posh'one seems to have holes either ends for the cables...
Will look at lights and have a think.
I guess you have to drill through somewhere to get the cables in?
Post #489914 8th Jan 2016 12:22pm
JOW240725
I don't know if it will help or if you have seen it already but MCMA1 thread shows an awful lot of wiring information he has carried out.
http://www.defender2.net/forum/topic40056.html
Post #489920 8th Jan 2016 12:41pm
Stacey007
^ Eeek,
He looks like he know's what he's doing as well,
Looks great but a lot of wires.... Smile
Post #489923 8th Jan 2016 12:54pm
