Home > Puma (Tdci) > Silly audio question
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Hi all,
For those of you (with endurance!) who made it through my my 'Newbie - Am I mad?' thread, you know that I am now, after much gentle persuasion by forum members, hopefully getting a 110 XS USW in a week or so!!
In best forum tradition, I've started my shopping/modification list.. Laughing
Quick question about the factory speaker setup in the 110XS. Do the front speakers have tweeters in the dash? If so, are there factory crossovers for these and the woofers/midrange? Want to replace the audio setup with something higher quality, but want to make sure I order the right stuff! I guess I need to order 10cm component speakers for the front?
In this vein, I presume that the rear speakers are just 10cm co-axial?
Cheers!
Post #43130 20th Oct 2010 3:31pm
mse
There isnt a whole lot wrong with the standard set up a replacement head unit and a sub of some sort wont massively improve. Mike
Post #43136 20th Oct 2010 4:59pm
Laurie
....and you won't be able to hear it anyway Rolling Eyes
Post #43140 20th Oct 2010 5:15pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
i like my music, classical, rock, jazz, all sorts. i like to hear my music cleary and thoughout the sound range.
after investigating a reasonably priced system i left the tweekers in place, replaced all 4 factory speakers with Kenwood 3 way speakers [they are 4" and not much bottom end but very clear, i also fitted a new Kenwood head unit with USB slot and fitted the Alpine powered amp behind the cubby box.
now i get very clear sound all the way through the range which suits me fine.
[/img]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  BM52
Post #43156 20th Oct 2010 7:34pm
discocuzzy
Ohh yes it does Mike Thumbs Up
Check out this thread for info
http://www.defender2.net/forum/topic2716-15.html You cannot teach stupid people to do clever things
Post #43158 20th Oct 2010 7:47pm
szracer
Thanks chaps.
I'm also after clear sound rather than boy racer thumping bass!
Think I'll be going for one of these as a head unit:
http://tinyurl.com/3ybvn6e
since with a bluetooth add-on I can link it to my iphone for sound and calls.
Swapping the speakers out and probably fitting a small sub somewhere.
Luckily, the second item on my shopping list is some sound-proofing! Smile
Post #43165 20th Oct 2010 9:23pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
The best place for the STD speakers is the bin Thumbs Up
Post #43166 20th Oct 2010 10:00pm
mse
With the exception of the sub - the standard system is no different to the one fitted to 300 Series discos, lower spec TD5's Disco's - nothing wrong with it.
An audio guy first advised on the discos to change the head unit for a decent one, which i did and had to hand it to him the difference was marked.
Im not saying it cant be improved, but, with a sub and headunit it will improve.
There are however 2 differencies - 110's longer than a 90 so sound probably is an issue differently for you 110 people and some of the voids arent as great on the speakers.
Granted there is no base on the standard set up Mike
Post #43180 21st Oct 2010 6:54am
