Home > Maintenance & Modifications > 90 Rear Recovery Points - is there a solution?!
Orangesofa
United Kingdom 2013 Defender 90 Puma 2.2 SW Keswick Green
I might be venturing into a topic for which I will be told to search as this has been covered to death but please hear me out – it is different this time – I promise!
I have decided to join a local LR club for a spot of mud play and one prerequisite is ‘recovery points front and rear’. Yep – makes sense and the front is sorted by the recovery points attached to the steering guard/chassis. Now the rear is a whole different story…
I have a 90 2.2 on a 13 plate with the tin foil crossmember which limits the choices as below:
JATE rings – cannot fit them easily due to the location of the fuel tank. To fit cast rings I’d need the tank out which is the devil’s work apparently.
Tow bar – I have one of these gathering dust in the garage which I duly removed within days of getting the car as (1) I don’t tow and (2) if I am going off road, the last thing I need is a built in plough to help me get stuck. Besides, is a 3.5t rated tow ball (or DB jaw) a sensible recovery point?? I gather not. I could go for a D&B 5t Camel Jaw but at £150 it is a tad pricey and I still have the plough issue...
QT Swivel and Shackle – mounts to the tin foil cross member and due to the fuel tank (again) the supplied backing plate cannot be fitted, not to mention the threaded crossmember holes would present an issue even if I could get to the back of the crossmember to fit the reinforcing plate.
Rear Recovery Eye – the one supplied by Extreme is welded not cast so may not be the best choice not to mention the whole fitting to the crossmember issue (see above).
LR Crossmember Reinforcing Kit
(+ a recovery point of some type) – I thought I was onto a winner with this one then having thought about it I may not be so sure. A straight pull is going to rely on the threads in the crossmember sharing the load. The material they are mounted into, namely the foil of the crossmember, presents a weak spot – no? The more lateral pull is helped by the reinforcing plate as it will spread the load over a larger surface area but I am not so sure this is the answer. If you look at the tow bar kit, it has tow arms which reach back to the chassis which is most likely for a very good reason. This leads me to what I think is the answer – perhaps the only answer…
2” receiver mounted to the crossmember with the arms running back to the chassis - the only drawback I see with this one is that it is nearly £200 for the receiver then another £50 per attachment. As I will only want a shackle eye – it is a mighty expensive solution and doesn’t give me the recommended 2 recovery points to share the load.
So – that is my take on the problems with each of the solutions and I would really welcome some ideas on what could work that wouldn't cost me the earth.
Have I missed anything? How does everyone else get around this?
I have two JATE rings going spare that would be perfect but dropping the tank appeals about as much as sticking pins in my eyes. Does anyone have any experience of getting JATE fitted to a D90 with rear fuel tank?
I did ponder speaking to a local engineering firm to see if they could fabricate something to use all of the existing threaded holes in the crossmember plus build some arms to the chassis but reckon I might end up back in the £200+ category.
Thoughts/advice very much welcome… Phil
Post #487857 2nd Jan 2016 6:35pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I assume the way the tank fits is different to the 110s I am used to as you have to remove the JATE rings to enable you to drop the tank.
The army use the NATO towing pintle that bolts through the crossmember and does not effect off-roading, they are a great bit of kit with minimal maintanence, ie clean and grease. They are normally for sale on eBay and often a member has one in his shed up for grabs also. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #487873 2nd Jan 2016 6:51pm
Orangesofa
NATO Pintle is the same principle as anything else mounted directly to the crossmember. The solution is only as strong as the weakest part and in this case - it is always the crossmember.... Phil
Post #487877 2nd Jan 2016 6:58pm
ibexman
Post #487881 2nd Jan 2016 7:06pm
Orangesofa
Yep - rear recovery eye in OP. Surely this is relying heavily on the strength of the crossmember screw threads plus the eye itself is welded to the backing plate. Not too sure I would trust that set-up to look like that after a snatch recovery.... but would welcome people's experiences Very Happy Phil
Post #487882 2nd Jan 2016 7:10pm
ibexman
Bolt your tow kit on for play days Whistle
Post #487883 2nd Jan 2016 7:12pm
g-mack
Post #487888 2nd Jan 2016 7:24pm
g-mack
ibexman wrote:
i wouldn't use it like that to pull out weeds Very Happy
i have one of them but have plates on front and back Thumbs Up though its easier on a 300tdi
 My 109 thread
my youtube channel
Post #487889 2nd Jan 2016 7:27pm
Anderzander
I've used a recovery eye bolted to the crossmember and pulled a lot more than weeds out with it.
In fact It's had a lot of weight on it - though I never go for snatch recoveries.
Post #487905 2nd Jan 2016 7:44pm
leeds
What sort of 'mud play' do you intend doing with your local LR club?
Competition use or the occasional RTV trial?
If only RTV then the idea of a correctly set out trial is that not too many vehicles will get stuck and then only lightly stuck. OK purists might argue against it but normal towing equipment can be used with care.
If you intend to get your vehicle stuck in deep mud holes then that is a different story.
What condition is your rear cross member in? Brand new or been attacked by rust worms? If the latter that might need sorting out first.
An alternative rear recovery point would be this. Has the advantage of being able to attach a rope or strap direct to it without using a shackle. Combine it with this reinforcing plate
Brendan
Post #487909 2nd Jan 2016 7:56pm
dantastic
I have one of those for my 110. Great piece of kit.
But I would avoid snatch recovery if at all possible.
Post #487911 2nd Jan 2016 7:56pm
Pilgrimmick
Regardless of what you fit, only use a snatch recovery if you have inspected the vehicle making the recovery, that is not practical most of the some, so do not use it as a recovery method. It is DANGEROUS, unless everyone knows exactly what they are doing.
Post #487913 2nd Jan 2016 7:58pm
leeds
Also do not forget the three most important bits of recovery equipment.
Eyes to assess the actual situation.
An engaged brain to work out the safest way of carrying out the recovery.
A shovel to reduce the possible forces involved.
Brendan
Post #487918 2nd Jan 2016 8:11pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Cut the X-Member off and fit one of these
https://www.devon4x4.com/d44-heavy-duty-re...57747.html
Post #487919 2nd Jan 2016 8:12pm
Use a Dixon Bate 3.5T ball and pin hitch, this's will give you a very strong centred tow point capable of taking both.
There are also 5T versions.
Or use a NAS step with regular ball at the lowest point and singular hitch above. Or like me use a 3.5T ball and pin in one unit.
Post #487922 2nd Jan 2016 8:23pm
