![]() | Home > In Car Electronics > Car wont start and dash lights come on and then go off. |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2049 ![]() ![]() |
Probably flat battery.
Riyo Member Since: 26 Jun 2014 Location: Aberdeen Posts: 89 ![]() ![]() ![]() |
Ok, i have took the two batteries out and put one on trickle charge, hopefully that will cure it. I dont have a multimeter handy so couldnt get a voltage off it.
I forgot to start the ignition and then remove the negative within 15secs, i just took the battery off - will this cause me any issues? Also is there a special charger needed for the Odyssey sealed batteries?, i found one in the garage thats just a little black box with pos and neg wires coming off it and 2A on the front?. Thanks! |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
When you reconnect the batteries, sit inside and press the fob to lock 4 or five times until it does.
Then unlock it straight away again on the fob and try and start it. Sounds like flat batteries, but also make sure the battery terminals are tight. ![]() |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2769 ![]() ![]() |
Yep flat battery sounds like, or loose earth cable on the battery. Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
With a 2 amp charge it will take at least 24 hours to fully charge the battery, maybe even longer dependent on the ampere hour rating of the battery itself. If it's a PC 1700 nearly a day and a half as it is rated at 68 a/h. Odyssey batteries can be charged at a rate of 50 amps if you have a charger big enough apparently. If you go through life with your head in the sand....all people will see is an ar5e!!
Thanks for the tips, its been on charge overnight so i will give it a blast this afternoon.
Cheers, |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
As previously mentioned, don't be caught out by the immobiliser!
![]() Hope all goes well. |
Check the (in)famous "main relay" Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
Good job I read this ![]() We don't like being old in the first place, so it doesn't take much to ![]() Richard |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 ![]() ![]() ![]() |
It's in the owners manual... It's not uncommon either, just a procedure to stop the alarm sounding...
We blokes don't need manuals we already know how to do it.
cool beans, stuck the charged batteries back inm 3-4 flicks of the fob on and off to resync and started straight away. Guess il need to stop leaving her on the drive unattended for long periods of time.
Thanks for the help folks and Happy New Year! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
If you do need to leave it unused for significant periods why not leave an intelligent charger such as a Ctek connected? Keeps the battery in tip-top condition.
