Home > In Car Electronics > DEFENDER INTELLIGENT INDICATOR MODULE |
NJS22 Member Since: 26 Oct 2012 Location: Cornwall Posts: 169 |
Just fitted the Alive Tuning intelligent indicator module to make then one touch three flash things.
The kit said plug and play and it is as long as you either have hands the size of a three year old or are prepared to remove the dash. The connection they suggest is at the rear of the ignition barrel and a nightmare to get to so much so I managed to break one of the pin connectors and then had to run to the steeler for a new ignition switch. So today I spent the morning removing the dash and finally gaining limited access to fit the new ignition and the indicator module. Now I like my add ons and have done quite a few to my Defender but I have to say this was the hardest, all I wanted to do was warn people that they are not as easy fit as the website suggests. That said they work a treat 1998 90 50th Anniversary 4.0 V8 2016 90 Adventure 2015 Range Rover Sport 1971 Range Rover 2 Door Wife won't let me have any more...!!! |
24th Dec 2015 7:50pm |
