![]() | Home > Wheels & Tyres > Steel vs Alloy: Urban Myth or based on hard evidence? |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Hit a rock with alloys on a D3, took a large chuck out of it, it still was ok to drive luckily but replaced with new wheel asap. Did same on steel wheel, which bent rim and reparied with a hammer. I should really look more at track than the view!!
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5857 ![]() ![]() |
Mach fives are 8J and steel.
I smashed two boost wheels, they went in so far that they were rubbing the brake disc ![]() ![]() But one chap in flip flops, sun glases, and gas bottles, all straight. Well enough to continue holiday, and get me home. Andy |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
Four trips to Morocco which involved 2 comps. Challenge events and loads of 4x4 laneing and various events in the UK using new Land Rover Products. Never bent a rim. Check the terrain and drive accordingly simples
RLD Member Since: 29 Jun 2007 Location: Lancs Posts: 858 ![]() ![]() |
4 tries to Morocco 1 to Poland 1 to Norway i to Coatia and all over England 140000 miles of every sort not bent a rim need to look at what you are doing
Ok, to justify my above photo........
I was over taking a lorry in Morocco, when he decided that he did not want to be overtaken, and just shoved me towards the rock face, so there was not much I could do. I have replaced with new alloys, as I don't plan a repeeat, and don't think steel would have been any better. Andy |
Yes have bent a steel wheel. My error! Managed to get a replacement disco wheel as a spare for the 110
On my travels normally carry two spare tyres/rims plus a couple of inner tubes. One thing you want to consider is ease of replacing a tyre whilst on your travels. Took a week for me to get a replacement tyre and it had to come over a 1000+ miles We run on 255/85/R6 which is about 6mm taller and 30mm narrower then your 285. For overlanding consider a good compressor possibly an engine compressor, tyre repair kit etc. HTH Brendan |
KarlB Member Since: 08 Feb 2010 Location: Canberra Posts: 91 ![]() ![]() ![]() |
Another argument re steel vs alloy rims is that tyres may be eaier to change on steel rims.
Cheers KarlB |
Wot he said
a 285 KO/KM2 will flop easily on to a 8J modular rim with little effort nice easy field beer oclock change ![]() |
Not much difference between ally or steel when changing a tyre in the field. if you carry the kit to do the job
![]() I have one of these and a couple of good tyre leavers. Even 19" MTR's dont pose a problem. ![]() Click image to enlarge 130's have feeling's as well you know ![]() |
I heard Carl has a proven tyre demounting method
Yep
