Home > Off Topic > Trickle Charger recommendations
Page 1 of 3 123>
leeds
We use a ctek charger for normal battery charging duties.
However I need to keep various batteries charged this coming winter.
Any recommendations on trickle chargers??
Charging batteries in parallel, normal wisdom is to keep to the same type of battery in same condition.
Would the same apply to keeping them top up on a trickle charge? Logic seems to say yes.
So any recommendations on trickle chargers and advice on trickle charging
Thanks
Brendan
Post #480396 8th Dec 2015 8:43pm
You won't find anything better than a Ctek. I would try to avoid charging multiple batteries in parallel since any variations in the batteries could cause problems, and an internal fault in one could, in the absence of protection, discharge or even short the others with undesirable result.
I keep any vehicle I'm not actively using permanently plugged into a Ctek pretty well all the time now.
Post #480480 8th Dec 2015 11:40pm
Harry.O
+1 for the C-tek, they can be left on the battery indefinitely and I've never had a problem with them. One of them lives outside and has survived a winter with no issues.
I bought a Lidl one a few months back, for £15 it's coped very well charging Puma batteries from dead. It can be fitted to the battery long term and automatically reconditions like the C-tek.
The Halfrauds ones are mean to be quite good also.
Post #480530 9th Dec 2015 8:39am
ethanicus
2014 Defender 90 Puma 2.2 XS CSW Corris Grey
+1 for ctek chargers. I use the 0.8 xs as maintenance charges for winter storage. Just fit and forget. Never had any issues.
Post #480532 9th Dec 2015 8:46am
C-Tek Thumbs Up
Post #480536 9th Dec 2015 9:09am
leeds
Looks like I will be buying a few more Ctek chargers Thumbs Up
Currently have 2, one is about 3.5 amp, one is a 7 amp one. The 7 amp one at 6 years old is not working at the moment, not had time to check the fuses yet.
Brendan
Post #480549 9th Dec 2015 9:42am
It certainly seems to make sense, with any type of vehicle that is not used constantly, to plug them in permanently
to a CTEK. Very impressed with mine and I think it has paid for itself in not having to replace batteries every 3 or 4 years.
Post #480592 9th Dec 2015 11:45am
TJ101
Also use a couple of Ctek for the trickle charge jobs
then a GYS Batium http://cheshirebatteries.co.uk/chargers-te...arger.html for proper charging California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #480598 9th Dec 2015 11:53am
Cupboard
Shame you missed the deals Amazon were doing on the Ctek
Post #480648 9th Dec 2015 2:15pm
AJC
I have a CTEK one on my old escort,
I also use an Accumate
but i do have 3 x £10 ALDI ones and in all fairness they all do exactly the same job for the price of one CTEK.
Post #480695 9th Dec 2015 6:01pm
Romadog
Just to be different.... Whistle
I have a Halford's one and it seems to work fine Very Happy Thumbs Up
Post #480708 9th Dec 2015 6:15pm
Seriously - they have the same 7 or 8 stage charging & maintenance modes?
Post #480722 9th Dec 2015 6:43pm
AJC
Yes. It keeps the battery charged. That's all I need.
They even have a digital display showing volts and how charged it is etc.
Only thing that lets them down is you can't unplug the crocodile clip cable from the charger like you can with my c tek.
Post #480724 9th Dec 2015 6:46pm
treps
For other cars I normally use an Optimate 6 which I have for the bikes... Has worked fine.
What model CTek do you recommend?
Post #480736 9th Dec 2015 7:06pm
g-dog-s
England 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
I have a CTEK MXS5.0 (not the Test & Charge) which is fine for 1.2Ah to 110Ah batteries inc lead acid, AGM & gel.
This does the job on 12Ah gel & 16Ah lead acid motorbike batteries as well as looking after the batteries on a D4 (AGM) and 110 Puma (lead acid)
(Individually, that is, not all at the same time!)
The cars are charged via the towing electrics using an adapter bought from Martin of this parish
Post #480808 9th Dec 2015 9:36pm
Page 1 of 3 123>
