Home > Technical > Anderson connector for winch/compressor/jumper leads |
Cupboard
The reason I came to the conclusion I did is simple.
Given a full budget and enough time, then run 50 or 60+mm2 cable back to the battery and buy plenty of shackles, strops etc.
Given not a full enough budget or time, then use existing cabling that will be fine for most applications and is already suitably protected and then spend the money you've saved on good quality recovery gear that won't fail dangerously and potentially expensively. If you limit your winch to 80% of its maximum potential pulling power, you'll be well within the current carrying ability of the cables (and remember we're talking about the difference between 40 and 50mm cables here, these winches will pull more than a 50mm cable can carry if the battery will let it).
A TDS Goldfish 9.5i will draw 340A at 9500lbs and 7.5F/M. Halve the pull with a snatch block and you're looking at 12.2F/M at 210A with the option of going to much higher pulls. So given a limited budget, the second option is slightly slower (by about 1 foot per minute), has more recovery potential and is putting a lot less strain on the winch and electrical system.
Like I say, the absolute best option is a fat cable right back to the battery, and put as many big batteries in as you can.
The next best option (IMO) is still safe, which is the most important thing, and works, which is the second most important thing. It's all about priorities really. I'm not saying you should do one or the other, just do what ever you do knowing as much as you can about it.
9th Dec 2015 2:04pm |
