Home > Td5 > How fast is a TD5?
miker
How fast is a TD5?
So, sounds like a strange question at first, right? It's a Land Rover, they're meant to be slow!
I've just picked up a 1999 110 CSW, and I know it has/had a running problem. Boost wasn't coming in until very high revs. This seemed to be made better by replacing the MAF, it was a bit there/not there for a day or two, but now seems to be boosting nicely. I have also twiddled the turbo actuator. Whilst very firm, I would say it moves freely.
HOWEVER, I have no idea how much power it 'should' have. for example, going up the hill near reigate on the M25 clockwise, if I'm doing 70 then it will struggle to maintain it unless I drop down a gear. Is this normal? I suspect not but have no frame of reference!
In the future it will get a remap, but I will make sure it is fully healthy before that point!
Post #474093 19th Nov 2015 2:26am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
My 2000 110 has just a Romerdrive., (no remap or changes to the intercooler or turbo) Goes great on the flat, but once off the flats on an uphill it needs the lower gears (4th and 5th) to keep it in the 120km/h range.
Post #474100 19th Nov 2015 7:14am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
I'd recommend taking it to one of the many favoured tuners to have it all checked, someone who knows what the ECU values mean and not just the error codes.
My TD5 has been tuned for so long I can't remember what it was like on the motorway before but I definitely don't need to use anything below 5th from about 40mph to another number much higher.
Assuming it is mechanically sound the common MAF issue can cause performance degradation, increasing the pressure before the actuator operates won't make much difference as you can't really go anywhere before you start to trip on over pressure.
Try in unplugging the MAF, clean the MAP sensor on the inlet manifold and check your red ECU plug under the drivers seat for oil. www.td5.org
Post #474105 19th Nov 2015 8:03am
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
My 2003 TD5 can go 120km... Wink
Post #474123 19th Nov 2015 9:49am
keith
126 MPH . 2006 Whistle
Post #474136 19th Nov 2015 10:50am
Alive Tuning
Hi All
As far as Defenders go, this one is pretty quick! Check this out.
https://www.youtube.com/watch?v=IEiMa-Vz8N8
Alex Divers
Post #474138 19th Nov 2015 10:56am
Laurie
The handbook says 89mph max. governed speed.
Post #474146 19th Nov 2015 11:39am
miker
It's more maintaining speed than absolute top speed I'm concerned with! Just not sure if it's down on power. There is oil in the ECU plug, doesn't feel like it's misfiring but I'll blast it out with contact cleaner and see if it goes away.
MAF is brand new but worth checking, will also clean up the map sensor.
What are the options on diagnostics? I have a Bluetooth obdii adapter and torque app, which works great on other cars but I can't get anything out the defender!
Post #474147 19th Nov 2015 11:47am
HossBog
Mine's standard and it sat on the M40 at around 80-85 quite happily.
Bloody loud though. 2002MY Defender 90 H/T
Post #474151 19th Nov 2015 12:11pm
jimbob7
Very limited,the only diagnostics you can get will cost £300 give or take.They have obd2 ports but nothing is compatible apart from Hawkeye,Nanocom or what I have, Lynx.
Whats acceleration like on the flat,you should easily notice the difference when the turbo kicks in if you floor it in 3rd/4th? Pov.spec,ftw. 2006, 110,TD5.
Post #474159 19th Nov 2015 12:35pm
mk1collector
If there's oil in the ecu then that's probably your problem. Ray
My build thread
Post #474216 19th Nov 2015 3:39pm
miker
You can definitely feel the turbo come in, and it does pick up, but I'm not sure if it's as much as it should!
I thought that the oil in the ECU would cause a misfire, but I'll sort that and see how we go.
Post #474355 19th Nov 2015 9:25pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
140km/h top speed. on a def90 it starts to feel scary. (tried this when i has a 1.410 box.)
it will cruise at 120km/h at 2400rpm with 1.222 t-box, which doesn't strain the engine at all. engine temp at 82 deg while ext temp is 32 deg.
If you really want to keep the speed then a 1.222 t-box is a good choice. some say you lose power, but only when moving off, if you don't tow, you never really notice it.
using the standard turbo and a uprated cooler will give you enough power on a 1.222 box to tow. The defender has migrated, leaving the owner behind.
Post #477558 30th Nov 2015 4:20am
