Home > Maintenance & Modifications > Would anyone recommend WHEEL SPACERS?
Page 2 of 2 <12
My 110 did 120k miles mainly near GVW on 285s with 30mm spacers and at180k now is still on original wheelbearings on 3 of 4 wheels, and on original swivels with original shims. The 4th wheelbearing failed for other reasons.
It's now on Blindos with reduced offset and on 255/85.
The idea that your bearings are doomed if you run spacers really is an old wives' tale, bunkum. If you ran 150mm spacers, then maybe.
Post #473714 17th Nov 2015 10:16pm
JAY BOY
Wales
I've run them on mine and had no problems what so ever.
Go for it.
It make a huge difference on turning circle and handling is also better.
Post #473719 17th Nov 2015 10:30pm
Hairy Beekeeper
United Kingdom 1990 Defender 130 200 Tdi HCPU Aintree Green
On the insurance issue, can you tell them that they are a safety upgrade?
If you have to swerve at speed, you're more likely to stay shiny side up. A bit like when they started putting brake lights in spoilers to claim the same thing.
HB Currently rebuilding my stretched 110 (now 122) to personal spec, probably going to be a double cab dropside, but not fully decided yet. So I've started at the front end first!
http://www.defender2.net/forum/topic41658.html
"Sorry love, don't make me choose between you and my Lanny. You won't like the answer....."
Post #474182 19th Nov 2015 12:50pm
Page 2 of 2 <12
