Home > For Sale & Wanted > [For Sale] Ashcroft ATB 3.54 Diff, 4k miles
jst
Just bought a 90 today that has come with an Ashcroft ATB in the rear axle.
The diff was built up by Ashcroft on an exchange basis, cost over £750 new only 4k miles, built up with exchange diff. inc VAT
info here: http://www.ashcroft-transmissions.co.uk/li...t-atb.html
3.54 ratio
Std LR pattern diff (ie not P38 fitting)
Located near taunton
Buyer either collects or arranges collection.
Would like to see £600 for it. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #471429 10th Nov 2015 9:25pm
jst
Diff is out of the vehicle now.
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #473627 17th Nov 2015 7:56pm
Worth remembering that if it's from the rear of a 90 it will fit the front axle of 90, 110, and 130 models.
Good luck with the sale. Thumbs Up
Post #473633 17th Nov 2015 7:59pm
jst
correct, thank you Blackwolf Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #473665 17th Nov 2015 8:47pm
pad
England 2007 Defender 90 Puma 2.4 HT Zambezi Silver
ATB
PM sent
Post #473769 18th Nov 2015 6:50am
rfkdemon
United Kingdom 2000 Defender 90 Td5 Silver LE Zambezi Silver
Pm'ed Smile
Matt
Post #473810 18th Nov 2015 9:42am
jst
Still for sale, and havng now studied the paperwork its done about 500 miles not the original 4k first thought! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #509587 1st Mar 2016 2:38pm
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
never seen inside a diff before, very interesting - looks like an instrument of death for Mad Max Dog
Post #509614 1st Mar 2016 4:23pm
jst
Still about Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #513107 11th Mar 2016 8:52am
Wormhole54
United Kingdom 2007 Defender 130 Puma 2.4 HCPU Zermatt Silver
Hi,
Do you still have this? Why did you take it out?
Matt
Post #513329 11th Mar 2016 7:09pm
jst
Hi Matt, yes i do. i run 4x4 driver and recovery training courses. i bought the vehicle as a training vehicle and wanted open diffs for teaching. Other vehicles are running air lockers, so its surplus. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #513355 11th Mar 2016 8:32pm
jst
Just to clarify on here, i know you can buy the diff centre for £295 (+carriage + VAT) from Ashcrofts this one is a built up one, built by Ashcfrofts, with new bearings (£20) and with the actual diff casing. it cost in the region of £750 from Ashcrofts with exchange diff.
If you want an exchange i will sell it for £500 on receipt of your old working 3.54std rover diff.
this diff will fit front and back of a 90, front only on a 110. i personally would only fit it in a rear axle.
They do work very well with ETC as resitstance is applied to the spinning wheel by the ETC engaging the diff quicker than a non ETC vehicle (bit like left foot braking) Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #518275 27th Mar 2016 7:22pm
jst
further to text above, to reply to many PMs and confirm to all,
this is a buy it,
unbolt your diff,
bolt in this diff,
Put your now spare diff on the shelf so you can change back over to std diff if you move your truck on etc.
it fits:
front of any Defender, - although i would not fit it in the front for my usage.
Rear of a 90.
Edited: Will fit Discovery front and rear.
It is:
Fully build up
low miles
low usage
does not need anything else to make it work (ie air like an air locker)
It does:
work especially well on vehicles with ETC.
I hope this clarifies Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #522142 8th Apr 2016 9:26am
rallysteve
Not sure that it will fit rear of any age of 110, pre/early TD5s had Salisbury axles with hypoid type gear sets, to my knowledge never had rover type spiral bevel diffs/axles fitted.
Post #522152 8th Apr 2016 9:44am
jst
good point, my mistake not thinking outside of rover p38s! will chaneg post thank you Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #522158 8th Apr 2016 10:12am
