![]() | Home > Maintenance & Modifications > ARB Intensity LED Driving Lights or maybe something similar |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 200 ![]() |
The trouble is that the largest market for auxiliarly lighting is probably those who want it "just for show". Such people often champion as much "power" as possible and the raw lumen figures therefore play straight into the manufacturers hands.
![]() The problem has been accentuated with LEDs - they produce their light in a (roughly) 180 degree spread, but most of it is produced in the 90 degrees or so directly in front of them, and the "hotspot" (if one could still call it that) is also generally several degrees off centre. The upshot of this is that if you stick an LED, facing forwards, in a reflector in the traditional position, most of the light doesn't hit the reflector at all (hence reflector facing LEDs are coming into use) - so you can get a great lumen rating, but maybe 80% doesn't go where you want it. ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
I believe all that, but presume your LightForces are E marked? My point is that if you want to wire the ARBs up as driving lights, no matter how good diffusers may be, they still will have to be E marked in order to be road legal. The China man statement that it is not necessary anymore to buy euro lights doesn't stand the test I think. If a driving light is not E marked, it can only be wired up as an off road light and used like that. No doubt Brendan could confirm or correct me. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
To be legal, yes, they have to be E marked, but, in practice, these are only for use with main beams and so as long as one A) is careful and considerate, not blinding oncoming traffic, and B) ensures they aren't active during any testing (either by means of a switch or simply disconnecting them), it doesn't actually matter.
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 ![]() ![]() ![]() |
and here was me hoping to put together some Camel Trophy esk quad roof rack lights and, since i have no space left for additional switches, just wire them into the high beam... hmmm
![]() will have to think of another accessory for the pretty girl Mike |
