![]() | Home > Puma (Tdci) > Ashcroft MT-82 shaft fitted today |
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
There will always be a feelable difference when matching shafts to gears Pickles. It's quite noticeable when you're assembling gearboxes as I used to.
The company I did my apprenticeship with had a tolerance of + or - 2 thou on all machined parts and I matched parts which gave the best feel ..... and if couldn't get a decent fit I'd go to the store and draw out more parts and return the ones I wasn't happy with. I can't see that happening with the way these last Deafeners appear to be slapped together during the Ford days. In fact, because of the obvious penny pinching cheap nasty things they've done to various areas of the Deafener I'll never ever buy another Ford product. As the independent bloke I have been using hasn't answered my query as to where this replacement kit (not Ashcroft kit) comes from I'll try someone else..... one thing I can't stand is the assumption that I'll be back anyway so why bother answering queries. The age of electronic ignorance..... AlanH. |
Not so long ago I had chance to drive several Puma's, all new and with only a handful of miles under their belt. The difference in the amount of drive line backlash and noise from the diffs and gearboxes between the vehicles was really quite remarkable. One was as smooth as silk but the rest either whined or had poor synchro, clunks and / or incredible amounts of transmission shunt. Steve.
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6266 ![]() ![]() ![]() |
It's all about QA and tolerances. QA meaning quite a lot
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
[quote="Happyoldgit"]Not so long ago I had chance to drive several Puma's, all new and with only a handful of miles under their belt. The difference in the amount of drive line backlash and noise from the diffs and gearboxes between the vehicles was really quite remarkable. One was as smooth as silk but the rest either whined or had poor synchro, clunks and / or incredible amounts of transmission shunt.[/quote] Don't get me started, the quality of fords vinyl! Td5 still look better ! Anyhow I don't understand why for all the clunks and whatever that burgers the hell out of me, I still could not sell it! I love seeing others enjoying the hell out of them and the wave. Her indoors still doesn't the wave but complies
Just to revive this thread a bit.... I mentioned earlier a kit being used by the indy I was using in Perth WA and he has now advised me it was made up from original parts from LR. He's now not sure it's the best solution and advises me to get the Ashcroft stuff fitted.
He normally does this upgrade while fitting a new clutch or sorting g/box or transfer box problems none of which I seem to have (wonder why?) so I'm thinking of maybe getting the clutch done while the thing is in bits anyway. Bloody Landrovers...... AlanH. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17032 ![]() ![]() ![]() |
If your clutch is working properly and you don't have early indications of the 'death rattle', I'd be inclined to leave it alone.
To change the output adaptor shaft requires the removal of the transfer box (which is not insignificant), but the main gearbox, gear shift assembly, clutch hydraulics, and exhaust pipe can all stay undisturbed. All of these need to be removed if the clutch is to be changed. Roughly speaking you'd be doubling the amount of work involved. It is probably only worth doing if you think there is a reasonable likelihood that the clutch will need changing within the next year or so, and that will depend on whether you have early symptoms of imminent spring compression, the age of the clutch (later ones are better than earlier ones), and the mileage that the clutch has done and the vehicle does each year. Unfortunately it is one of those situations where you will never know if you've made the right decision - unless you decide to take the clutch out and find the springs fall out on the floor! |
