Home > Technical > 2.2 won't start...
Grease EME
England 2013 Defender 110 Puma 2.2 HT Alpine White
2.2 won't start...
I'm having some trouble with a 2.2 Tdci puma 2013 model, if you turn the key over quickly it will fire up but instantly shut down, if you turn the key nornally ( to check dash lights) it will not start or fire up at all. i've check possible broken earths and relay connections... but is now at a end... can you help in any way...
Post #469605 5th Nov 2015 1:54am
scotsstag
Scotland 2004 Defender 90 Td5 CSW Rutland Red
Give Land Rover Assist a call, after all that's what it's for, especially as it's such a new vehicle. Wink 04' 90 Td5 CSW..
Post #469608 5th Nov 2015 2:10am
Grease EME
cheers, i'll give it a go.
Post #469619 5th Nov 2015 6:13am
Happyoldgit
If you have not already done so a quick check of all the fuses and battery connections wouldn't go amiss. Steve.
http://forums.lr4x4.com
Post #469751 5th Nov 2015 1:25pm
Matt110
Where is the remote key fob relative to the main key... Is it hanging on the same key fob or have you separated them? That sounds like the immobiliser issue I had.
Post #469853 5th Nov 2015 7:37pm
