![]() | Home > Td5 > Td5 taking its time to start |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
Injector seals are very common, and relatively easy and cheap to replace
![]() As long as you keep the injectors in order, you won't need any reprogramming |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 ![]() ![]() ![]() |
How strange... my Td5 also did something similar this morning for the first time. Never had an issue before. Will watch with interest...
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Install a non return valve in fuel line as when pumps wear it allows fuel to run back 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20729 ![]() ![]() |
Glow plugs may want checking, I'm no expert but might be worth it as their very purpose is to aid cold starting.
Regardless of this injectors is of course another possibility but just thought I'd add the above. |
There is already a non-return valve in the filter head ![]() |
