Home > Puma (Tdci) > Turbo heat shield |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 |
I have just removed the heat shield on the turbo to check the bolt tightness.I would like to leave it off.Can I?HANDS WILL BE KEPT AWAY WHEN ENGINE IS HOT,I don't know if it protects the surrounding area from heat.
Thanks Puma 110 SW 90 V8 SOFT TOP |
26th Sep 2010 8:48am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Its there for a reason. Can I ask why you want to leave it off 130's have feeling's as well you know
26th Sep 2010 12:56pm |
It rattles now and again and I have to manipulate it's shape to stop it.I'm also going to remove the cat soon so the lower bolt holes will bo lost.So my thingking is to leave it off from now. Puma 110 SW 90 V8 SOFT TOP |
27th Sep 2010 3:17am |
BigGeorge Member Since: 08 Aug 2009 Location: Zurich Posts: 43 |
I would put it back on.
Not only are other items protected from the heat but I recall reading an article where it was explained that the Turbo unit needs to be kept warm as cooling off too quickly and then heating up again is not desired. Sounded reasonable... The rattling thing is annoying but maybe you can find another solution for that, instead of removing the shield completely (e.g. stiffing the heat shield with a peace of metal... haven't found the solution either.. ) The goons are trying to bring me down! Defender 110 SW MY10 useless piece of ... but I like her Defender 90 V8 50th Anniversary Series IIa 109 / 6 cyl. ex-fire truck |
27th Sep 2010 7:12am |
