Home > My Defender > my defender(s) 90 restoration |
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 |
From what I can remember from reading writeups on forums & magazines, a 200 tdi would be a straight swap, but a 300 tdi needs the engine mountings changed. The auto gearbox has a longer bellhousing too which puts the shifter into the seatbox area, but these things have no doubt been overcome by others before now. Best thing would be to try & salvage a 300 tdi and auto from a vehicle you can drive before purchasing, then you can verify they are OK before taking the time to bolt them in. Mark S
CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
22nd Oct 2015 10:22pm |
JR Member Since: 07 Dec 2012 Location: Auchtermuchty Posts: 532 |
I'd agree with Mark above.
There are 2 versions of the 200Tdi, the genuine Defender one is quite a bit different to the one from a Discovery. Most obvious difference is that the Defender version has the turbo mounted above the exhaust similar to the Turbo Diesel. There is also a different timing case. The Defender version will slot right onto the LT77 gearbox with no mods unless you're fitting power steering which my spares vehicle (also ex-Post Office) didn't have. The Discovery engine will fit with some modification to the exhaust and maybe more. Incidentally a Defender 200Tdi will NOT fit a RR Classic or Discovery because the timing case, which is in essence a naturally aspirated diesel one, fowls big style! A friend tried this a number of years ago. The 300Tdi engine is the same for both vehicles but you will have to make your own airbox fitment. |
23rd Oct 2015 10:33pm |
