Home > Camping, Caravanning and Holidays > Pull out kitchen / stove / sink for 110 |
Rich broom Member Since: 26 Jul 2015 Location: Tiverton Posts: 78 |
Won't be that hard to design and build one
8th Oct 2015 8:52pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3778 |
Hello
Your right but if an off the shelf item was available it would be good to see, |
8th Oct 2015 8:59pm |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 |
Hi Stacey. Are you after a stove/sink to be used INSIDE the defender, or whilst away camping?
I dont know if one is currently available, but one option would be to buy an MSS storage drawer, which takes up the space between the two wheel arches, with a slide out drawer. The inside of the drawer could be modified with a shallow sink, a stove and some storage space. The only difficulty would be neatly plumbing the gas supply to the stove and sink. Thats not impossible though. The whole thing could stow away neatly between the wheel arches when not needed. |
8th Oct 2015 9:20pm |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
http://www.globecamper.com/kit-camper-luxe.html this may give you some ideas
8th Oct 2015 9:52pm |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
sort of like this .... ??
Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
9th Oct 2015 10:58am |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
This is what I came up with.
http://www.defender2.net/forum/topic20716-60.html 2002 110 td5 |
9th Oct 2015 11:42am |
Thank all
Wyvern, that's the idea is that your set up. Any more pictures from the side etc, did you make it? Thanks |
9th Oct 2015 2:01pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
9th Oct 2015 4:09pm |
Hi Stacy
as Roma Dog says its a Dormobile set up and will fit all 110's The set up includes a water tank under the drivers side of the chassis, a pump under the sink and a gas bottle situated out side under the rear passenger side wing. there are more pics on my galley. - just yell if you need any more info Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
9th Oct 2015 8:08pm |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1645 |
I wonder if that would also fit a 90? See no reason why not? YOLO... You Only Live Once...
9th Oct 2015 10:05pm |
Hi Yolo,
yes this should fit a 90 as the unit is the same size as the wheel arches - I seem to remember some one had the same cooker as me fitted some time ago... Drop Dormobile a line and ask if you are interested . Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
10th Oct 2015 11:25am |
