Home > Maintenance & Modifications > There's a hole in my Defender...
Cupboard
The lovely and wonderful previous owner ( Rolling Eyes ) of my Land Rover has drilled lots of holes in the back. Most are fairly small (<10mm) so I'm covering them with foil tape before lining the back with Silent Coat and something wipe clean. However there are two big ones, about 40mm diameter like this:
They did have a bit of steel badly riveted on top of them which looked silly, cut things that lay on top of them and were generally annoying. Is there a better way of doing it that will give me a reasonably flush surface to put stuff on top?
Preferable cheap and easy Laughing
Also are three runners along the load bed of a 110 HT standard? I've taken them out because they were really tatty and am replacing them with some cargo rail from Mud.
Post #459882 2nd Oct 2015 5:48pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
grommets? 2002 110 td5
Post #459883 2nd Oct 2015 5:51pm
Jimb1978
Post #459885 2nd Oct 2015 5:53pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Can you not cut a square piece of alloy out and bond it with a 2k epoxy resin, either top or bottom?
This is how I have previously filled holes drilled in to Series wings etc before the Tig welder! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #459894 2nd Oct 2015 6:14pm
mk1collector
Put a piece of ally underneath and rivet from the top? But make sur you seal it. Ray
My build thread
Post #459895 2nd Oct 2015 6:15pm
SailingTom
It must have been me as the previous owner im going to cut a plug hole into the rear tub of my double cab, I get a paddling pool when it rains. The tailgate seals cant be genuine parts as they work to well Laughing
As said id put a grommet in it Wink
Post #459901 2nd Oct 2015 6:27pm
I have used this technique many times to effect "invisible" repairs in wings, etc., simple and effective. You can use Araldite (pref not the rapid one) and a heat source (hot air paint stripper, fan heater, SWMBO's hairdryer if she's out, etc) to cure the epoxy in minutes to full strength.
I've just realised that some of the repairs on my S1s done this way have been on for more than 2/3rds the life of the vehicle! Gulp!
Post #459911 2nd Oct 2015 6:43pm
Cupboard
Thanks Thumbs Up
So I need to get myself some slow cure epoxy, a bit of aluminium sheet and borrow my girlfriends hair drier she seems to have installed in my house.
Then just clean off all the crud from underneath Big Cry
Post #459937 2nd Oct 2015 8:11pm
ian series 1
Just make sure you put the hair dryer back where you found it......... Whistle 80" 80" 86" 88" 90"
Post #459946 2nd Oct 2015 8:31pm
Jimb1978
Cupboard wrote:
Thanks Thumbs Up
or just bung a grommet in it 2002 110 td5
Post #459957 2nd Oct 2015 8:55pm
ibexman
You could use a round metal or plastic conduit box cover Thumbs Up
Post #459962 2nd Oct 2015 9:15pm
ericvv
Re: There's a hole in my Defender...
For the last you mention there, two of these maybe? The good thing is they will float when water fills the space through the smaller holes. Whistle
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #460001 3rd Oct 2015 4:27am
ian series 1
^^^^have you got the part number for the above item? ^^^^
Rolling with laughter 80" 80" 86" 88" 90"
Post #460010 3rd Oct 2015 7:33am
Stue5
Italy 2005 Defender 110 Td5 USW Alpine White
possible a heater exhaust? mine had two holes like that for the heater. sealing my hole....... alli and white marine grad sikaflex bond and seal in one Thumbs Up Range Rover p38 4.6 99 lpg(gone Sad )
Post #460062 3rd Oct 2015 11:40am
Cupboard
I think it was either a heater or a generator, there was an exhaust that I removed underneath one of them.
The rear door seal was in a terrible way which would make sense with a generator.
Post #460441 4th Oct 2015 7:17pm
