Home > Td5 > Will this cycle carrier work on a Defender 90?
Gareth
I am looking for a good value cycle carrier, for occasional use. I don't want to spend a fortune and this seems ideal if it will fit. Anyone here used one?
http://www.halfords.com/wcsstore/libraries/document/146682.pdf 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #457762 24th Sep 2015 2:23pm
No, it won't clear your spare wheel.
Post #457764 24th Sep 2015 2:38pm
Gareth
Thats what i thought. Thanks. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #457765 24th Sep 2015 2:39pm
Pipmac
United Kingdom 2014 Defender 90 Puma 2.2 SW Keswick Green
This OEM one works, I had it from my sport but works on my Defender.
http://m.ebay.co.uk/itm/Land-Rover-Discove...nav=SEARCH
Only down side is if you have a 90 SW with kids in the back you need to remove bikes and unplug it from the mount before you can open the rear door. The tow bar/ chassis takes the weight though so it won't knacker the rear door hinges like the wheel mounted ones. Feels more secure than the tow ball fix ones also when you are bumping around green lanes because the mounting is solid.
Post #457771 24th Sep 2015 3:11pm
CarlS
2016 Defender 110 Puma 2.2 XS CSW Aintree Green
http://www.maxxraxx.co.uk/products.html
These might be worth looking at as an alternative Thumbs Up The spawn of AndrewS
2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead
2016 Mini Countryman Cooper S All 4
2019 BMW R1200 GSA Rallye Sport
Post #457792 24th Sep 2015 3:56pm
simon67
England 2004 Defender 90 Td5 HT Rutland Red
Check Pendle - bolt stays on carrier all the time and you just sort the bars
Perfect for a Def 90
Also check eBay, you need the slightly bent bars for the wheel
Post #457800 24th Sep 2015 4:36pm
mk1collector
Get one of these
http://www.ebay.co.uk/itm/Land-Rover-Defen...2a4b4724d3
They come up cheap on eBay quite a bit and the bracket bolts to the wheel carrier and pokes through the centre of the wheel and the actual bike carrier bit just slides on and I think there's a clip or bolt holding the two bits together. Ray
My build thread
Post #457876 24th Sep 2015 8:07pm
Anderzander
I have a Saris Bones carrier, which fits well.
Post #457905 24th Sep 2015 9:42pm
Gareth
Cheers folks. I think the spare mount will be ok, as it will only be occasional use, for 1 bike, maybe 2 if I feel energetic enough! 2021 Defender 110 X-Dynamic HSE D300 MHEV
1968 S2a 88 aka Bob
Post #457968 25th Sep 2015 10:45am
alexatnd
Can thoroughly recommend the MAXXRAXX bike carrier. Just took Gertie our 1999 110 on a 2K+ drive round France fully loaded with 5 bikes hanging off the back. Not a single problem!
Of course the starter motor brushes have just died but that's another story.
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost
Effie - 2004 110 TD5 County
Post #463777 16th Oct 2015 11:57am
Screbble
I too need to transport 5 bikes (on a 90) and after quite a bit of research it looks like the Maxxraxx is the one for me. I like the fact you can still open the rear door with the bikes on, and all of the weight is on the tow bar bracket. The integral ratchet is pretty good too. It won't suit everyone I know, but it ticks all of my boxes.
Great to hear it's worked well for you with a similar load on a decent journey. Thumbs Up
Any issues since?
It's on my (long) list for Santa!
Hope you sort the starter Very Happy
Post #464434 18th Oct 2015 6:41pm
alexatnd
Starter sorted ... apart from tightening up the nut on the stud. Bottom bolts fine, started fine, just can't get a ratchet in there to tighten it up. Seems lots of people don't bother! Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Post #464584 19th Oct 2015 9:30am
alexatnd
Any issues since?
No real problems other than self inflicted. My Trek has exposed cables running on the underside of the top bar. There are red plastic covers on the ends of the bike carrying bits and one of them came off. Result was that (front) gear changing cable was partially cut through and I had to have them replaced. Think it was due to me getting bikes in correct order onto the rack. not something that's an issue when you;ve less than 5 bikes, but 5 is a bit fiddly when they're all mountain bikes.
Post #464586 19th Oct 2015 9:35am
