Home > Wheels & Tyres > BF Goodrich AT TA KO2 - what pressure? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
If you not carrying load I'd say 32F 36R psi.
I'm currently running 32F 34R but only due to rear shocks. It's a bit low to the rear. 38in the rear is quite hard unless your carrying a load or towing. |
17th Sep 2015 7:28pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17539 |
On my 110 I usually run 36psi front and 46psi rear, increasing the rears to 60-65psi if at max GVW. So yes, 4.4 bar is correct for max load on the tyre!
You'll want to run a 90 at lower pressures, of course. |
17th Sep 2015 8:39pm |
