Home > Stolen > Lucky escape. broken into at 22:00
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Can't get over the cheek.not just braking into it, but 10 pm on a main road!!
Luckily they pushed the rear window through and unlocked the rear door, causing the alarm to go off.
Just put the rear window back in and added a few padlocks till I can get more security sorted tomorrow
 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #454837 13th Sep 2015 11:08pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Glad it turned out not too bad, considering....
Post #454839 13th Sep 2015 11:54pm
I'd watch it all night if you can, just to be safe but they might be back.
Easier said than done I know so I do sympathise.
At least they failed.
Post #454840 14th Sep 2015 12:02am
gazman
It's still here this morning. Hopefully the police will be here to finger print it later as it has a big greasy hand mark on it. Unfortunately the scum now also know the rear door is chained so it only opens a few inches.
I've only had the thing 3 weeks it must be a record. Other half is not impressed and wants me to get shut of it.
One thing that did worry me was the alarm stopped sounding after 30 secs to a minute even though the back door was open. Is this normal? 2014 - current ..... 2003 defender td5 90 (my car)
Post #454860 14th Sep 2015 7:08am
Caterham
Sorry to hear Sad
Glad you still have tho.
I this isn't the be all and end all but anyone considered putting a 'peg' on the fuel line to prevent it going too far?
What about a bit of string from prop to fuel line (damage limitation and all that?)
Post #454880 14th Sep 2015 8:34am
dorsetsmith
NO Exclamation
Post #454893 14th Sep 2015 9:04am
Caterham
don't listen to me but I'm sure it is correct.....something to do with keeping the peace. house alarms do the same. I believe on both you can adjust the run time and on house alarms I believe there is a max time period 5 or 15 mins?
hopefully someone else can confirm.
Post #454896 14th Sep 2015 9:08am
discomog
Recommendations are that residential property alarms should silence themselves after 20 minutes. If the alarm continues after 20 minutes it can constitute a "Statutory Nuisance" and police can obtain an order from a magistrate to enter the premises and silence it. I guess this only happens where the alarm is ringing for days rather than hours.
Post #454917 14th Sep 2015 10:43am
gazman
It's getting a better alarm and imobiliser fitted later now anyway with a proximity alarm which will chirp. Should be enough to wake the hounds at least! 2014 - current ..... 2003 defender td5 90 (my car)
Post #454925 14th Sep 2015 11:23am
