![]() | Home > Td5 > What Colour Blue? |
Hey guys,
Doing some research (badly) and I'm coming up stuck. What colour blue was available in 2000 for Defenders? Its a Genuine CSW 110 in Metallic Blue and I need to know the paint so I can get some made up for some replacement/touch up bits. Thanks as always guys ![]() ![]() Self confessed mileage hunter ![]() |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 ![]() ![]() ![]() |
Is it a dark blue? Could be Oslo blue?
Think your bang on the money Buckblu
![]() I really love the colour just needs a few bits touching up ![]() Self confessed mileage hunter ![]() |
Are you thinking of a change shaggy??
Not a change, but an addition....
Photos to come soon enough once all the paperwork is settled and it is home ![]() Self confessed mileage hunter ![]() |
Thank you
![]() Yes very lucky indeed, many hoops had to be jumped through before I got it all sorted and even now it has conditions so is currently being stored at a private location for a while which is killing me as all I want to do is drive it ![]() It is indeed for My Girlfriend but also as a backup/down time vehicle so I can still get to work while mine is having work done- which takes the pressure off me a bit as it means I can spend more time on jobs rather than having only a weekend to do any major work ![]() But as I say, all will be revealed soon hopefully ![]() Self confessed mileage hunter ![]() |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
Worth checking but not sure Defender was offered in Oslo blue, think it was a Discovery and Range Rover colour - could be Caledonian blue but check if available in 2000
Oslo was certainly offered on the defender, if I remember correctly it was from around 99-04ish, http://www.ebay.co.uk/itm/2000-Land-Rover-...7675.l2557
Also Caledonian isn't metallic ... |
Triple7 Member Since: 30 Aug 2015 Location: Down South Posts: 70 ![]() ![]() ![]() |
My 2004 TD5 90 is Oslo Blue
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 ![]() ![]() |
Just to add confusion to the mix - could it be Cairns Blue?
No I think Cairns blue is a lot lighter.
Save all the guess work I will take a photo tomorrow in the daylight and upload so we can all have a look. ![]() Self confessed mileage hunter ![]() |
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 ![]() ![]() ![]() |
My 1999 TD5 is Caledonian blue, never found the paint code as the tab was blank.
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
If it helps, the 90 below is Oslo Blue and the 110 is Cairns blue, Cairns is a little bit more purple under sunlight whereas Oslo goes a little brighter.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
I.AM_a driver Member Since: 11 Jun 2009 Location: Edinburgh, Scotland Posts: 404 ![]() ![]() ![]() |
My 90 is a 2001 registered county in metallic Oslo blue, paint code 644 on the VIN plate under the bonnet. Mark S
CONVOY for HEROES www.facebook.com/convoy4heroes www.lothian4x4response.org ------ Td5 90 Thread in 'My Defender' Forum |
